1967 F-100 project
- 67nukeford
Re: 1967 F-100 project
Dropped the cab back down, and installed the front clip back on. Engine looks pretty good nestled in there!
- 67nukeford
Picked up an aluminum radiator from Alloy works. Pretty nice piece. Had to do a bit of trimming, to fit it around the steering box.
- 67nukeford
And installed. Looks good.
Love...the radiator!
I ran a two speed 18" electric fan, (from an 80's Pontiac Fiero) on my early Bronco for over 8 years and man did it help with the borderline radiator size Ford had to put into the V-8 Bronco's dud to frame rail width!
- 67nukeford
That one is a 3 core, should be plenty of cooling capability!
- 67nukeford
I did end up replacing the bottom side of one of the doors, on the inside. Came out pretty good.
- 67nukeford
Body work time. Started on the drivers side. This was a loooooong process. Got to a point, covered it in epoxy. Found a few spots still needing attention, and went back over those. sprayed epoxy again. There may be a spot or two I may have to address again next spring.
- 67nukeford
Same with the passenger side. I'll shoot high build next spring on both sides.
- 67nukeford
Off she goes to storage for the winter. So, I'll try and keep up with this next Spring when she comes home again!
- hfdco4
Great progress. That door repair looks like it came out pretty good.
FE390PC
FE390PC
My RA has me hating winter, (even what folks call our "mild winter" here in Florida).="67nukeford"Off she goes to storage for the winter. So, I'll try and keep up with this next Spring when she comes home again!
Nice progress though and nice to see another perfectionist!
