New Engine for The "Speed Bump"!
- SVT522
Re: New Engine for The "Speed Bump"!
A view from the side. I used the mounting screws that came with the tank to secure it to the top of the 1-inch square tubing. It's
10.5 lbs lighter than the old in-cab tank. It also moved 120lbs of gasoline back in the truck as far as it good possibly go!
SVT522
ASE Master Automotive & Medium/Heavy Truck Technician
"The Speed Bump" 1967 F100 - 466 "Cobrajet", C-6 trans, 4.11 Detroit Locker
1969 F100 4x4 - 360, NP435, Dana 21
1973 Mach1 - 351 CJ, C-6, 9-Inch
1996 SVT Cobra #522
1987 F-250 4X4
1996 SVT Cobra #522
1987 F-250 4X4
Looking good Kevin!
1969 F100 Ranger LWB Big Block, factory bucket seats and behind seat storage (arrived 3/21/12) (and it was free!)
1986 Thunderbird Turbo Coupe 247K and still going strong! (sold with 251,758 miles on it!)
1986 Comp Prep SVO Mustang (1 of 83) "the original Fox body "R" model!!"
1972 Ford F-100 LWB SOLD 5/2/6
1995 F150 XLT Supercab (wanna trade for a Bump?)
- SVT522
I ran errands with the wife today, went to lunch with her, and then did yard work. I managed to occasionally sneak in the garage and I got the gas tank and its mounting frame painted this afternoon too! ![Very Happy :D](./images/smilies/icon_biggrin.gif)
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
1996 SVT Cobra #522
1987 F-250 4X4
- SVT522
Here's the gas tank waiting for next weekend to come! Rust-Oleum rattle can High Performance Enamel flows out pretty darn nice. ![Cool 8)](./images/smilies/icon_cool.gif)
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
1996 SVT Cobra #522
1987 F-250 4X4
Excellent!
- SVT522
The Mustang gas tank is permanently installed. I cut a hole in the bed today for the filler neck/cap. I plan on doing like Bobbyford did and cut down a stock in-cab filler neck and using a short piece of hose to secure it to the tank.
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
1996 SVT Cobra #522
1987 F-250 4X4
- SVT522
I cut down the stock cross member and bolted it on top of the frame. It clears the tank and the bottom of the bed where it's at. I welded nuts on the inside of the frame rails to make installation easier. I also welded the bumper bracket mounting nuts on the inside of the frame. With the tank frame securely mounted and the modified cross member bolted down there is zero flex at the rear of the frame.
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
1996 SVT Cobra #522
1987 F-250 4X4
Great job!
- SVT522
Shot of the wheel tubs and the filler door for access to the Mustang tank.
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
1996 SVT Cobra #522
1987 F-250 4X4
- BobbyFord
Nice work! ![Very Happy :D](./images/smilies/icon_biggrin.gif)
- SVT522
Bobby thanks. It's slowly getting closer to being done. I need to get some fuel lines and fittings to get the fuel to the carb. The next big thing will be paint. I'm also thinking of getting my hubs and axles redrilled to the Mustang pattern. My twin brother is a darn good machinist and can hook me up. There are thousands of Stang wheels available to choose from! I'm looking for something light and affordable.
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
1996 SVT Cobra #522
1987 F-250 4X4
Thanks for the "my twin brother is a darn good machinist" plug! My twin brother is building a darn cool '67 Bump ![Smile :)](./images/smilies/icon_smile.gif)
- PhantomoftheBumpside
B E A U T I F U L .
![Wink :wink:](./images/smilies/icon_wink.gif)
[SPDBMP]elgemcdlf wrote:Too long for a personalized plate but cool name.
-- ROB --
The collective money pit details...
-On The Road-
1990 * 1FTEE14YZLHA83xxx ..- 138 E142 __ E 18 __ 3P
-Projects-
-Spares-
-Recently Departed-
1997 - 4M2DU55P9VUJ46xxx...- 112 4 22 _ _ 8 D4 U 1F
1997 - Dodge Caravan
1987 - Toyota Tercel Wagon FWD
1978 - Winnebago Brave (Dodge D800FC)
1970 - F10YRJ80xxx ..............- 131 3 F100 D _4 G 02
1968 - F25YRC99xxx .............- 131 E F253 B 81 G C8
1968 - F25YRD69xxx .............- 131 C F254 E 81 A 24
-On The Road-
-Projects-
-Spares-
-Recently Departed-
- SVT522
I worked on the Speed Bump some this afternoon. I had to trim the rear bed support some in order to get the bed to slide all the way forward. If I had to do it again I would mount the tank 1" forward. Right now it's flush with the end of the frame. The filler access is good...I'll be using it a lot once the mighty "429 CJ" is going! ![Very Happy :D](./images/smilies/icon_biggrin.gif)
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
1996 SVT Cobra #522
1987 F-250 4X4
- SVT522
I finished my exhaust system this weekend. I cut and welded the tailpipes so that the 18-inch stainless tips exit out the side between the tire and the bumper at a 45-degree angle. They're 3-inch inlets and 3.5-inches at the tip. I used lap-joint stainless band clamps to secure the tips to the tailpipes. Next weekend I'm going to start plumbing the fuel system with AN-8 line and fittings.
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
1996 SVT Cobra #522
1987 F-250 4X4
