Brighter Headlights
Electrical and Wiring Forum Archives
oldschool
Brighter Headlights
Post by oldschool »
Want brighter headlights.....?? Read this.....
http://www.madelectrical.com/electrical ... ghts.shtml
Faithful Old Road Dog
re: Brighter Headlights
Post by Faithful Old Road Dog »
Most of the guys that installed halogens or higher wattage lights, ie 80/100w experienced the infamous Ford blinky blink syndrome. The wires in our old trucks can't handle the current draw. There was a tech article on the dark side that showed you how to upgrade your wiring and install relays in order to get the max volts to the lights. That also dropped the heat to the headlight switch. The headlights have a breaker switch that would cut power if it got too hot.
Keith, why don't we pirate that right up? :evil:
91Bear
Post by 91Bear »
heep70
Post by heep70 »
I installed the relays and it hasn't given me any slack yet. I like it.
Greg
1971 F250 "Highboy". SOLD to "Highboy_Firefighter_71"
2000 Subaru Outback limited.
2000 F250 4X4 PSD SuperDuty Crew.
2010 Polaris 800RMK Dragon 155"
2013 Polaris Pro 800 RMK 163"
1980 Built Toyota "Trail Rig".
My last 1971 "Highboy" pics
Lazy Jake
Post by Lazy Jake »
I read this "same" article in Hot Rod Magazine and marked it as a high priority thing to do. Now that I've read your post I'm going to order the kit and put it in my '68. You could do the same thing by procuring some relays out of a junkyard dog but, I believe I'll opt for the kit. I'll post some results when I get her done. Just now I have to get the factory oil pressure gauge to working.
Dale
1946 Ford business coupe
1968 Ford F-250 Camper Special
How much is a kit and what does it include? I had some relays (forgot what I paid) and I have little spools of wire, so the cost was minimal.
heep70
Post by heep70 »
I think I paid $30 - $40 for the two relays, spades, wire and shink tube when I did mine.
Greg
Docholiday72tx
Post by Docholiday72tx »
Hey Heep,
Did you use fuses in your set up? If at all possible could you post some pictures?
Doc :D
If it ain't broke....oh wait a minute....it is.
heep70
Post by heep70 »
No fuses, just a couple relays. I will PM you an article I used.
Greg
