The pan on my 390 has the oil drain directly over the crossmember so oil currently just drains all over the crossmember when draining. Where should the oil drain be on the correct OEM pan?
I'm tempted to just machine a new threaded bung and weld it in on the tail end of the pan, using lots of damp rags to keep the metal from getting too warm and lighting any oil residue.
Oil pan drain
Moderator: Ranchero50
Oil pan drain
Jeremy
1971 Ford F250 CS, SC, 2X4, 390, C6
re: Oil pan drain
Is the oil pan on your truck stock?
If I didn't have bad luck, I wouldn't have any at all!!!!
re: Oil pan drain
The 67 F100 w/352 that I had did the same thing. That was stock.
re: Oil pan drain
I don't know about the oil pan. I rebuilt the engine for a friend a number of years back, he provided all the parts and block. He then sold the truck to me, LOL.
Jeremy
- j41385
re: Oil pan drain
That's normal. My 360 drained there too. It's a pain in the butt.
1968 F100 Took the running 390 out, and installed a Built 300 with AOD.
Engine Video... http://youtube.com/watch?v=2xgYd2u79NU
- FORDification
- Site & Forum Admin
re: Oil pan drain
Most people just live with it, by building a sheetmetal 'channel' to divert the draining oil to a bucket....or they get their hands on either an FT pan (full sump) or a rear-sump pan out of a 4x4, either of which will keep the crossmember a LOT cleaner.
FT engine full-sump oil pan:
FE engine rear-sump oil pan:
____| \__
-O-----O- Keith
My '67 restoration video
-O-----O- Keith
- flyboy2610
re: Oil pan drain
My 390 drains on the crossmember as well. I'd say you probably have the OEM pan on there.
Red Green
you'd better be right.
Red Green
re: Oil pan drain
I sure could use that dipstick in the above pic.
