I have a MX transmission behind a 352. The trans has a seperate trans oil cooler closed to trans case on the passenger side.
May I use a new radiator with built in trans oil cooler and reroute the cooling lines from the case to the built in cooler?
Is there any experience made to this topic?
Has anybody a good source for MX rebuild kits and converters?
Roman
MX transmission - Coooling lines
- 68F250
re: MX transmission - Coooling lines
I've heard of other folks doing what you're contemplating. That auxiliary cool was not one of Ford's better ideas.
What about swapping out the ol' MX for a C6?
- cobraF100
I ran my own lines for my C6 and used an aftermarket cooler.
But Yes to your question if you can use the trans cooler that is built into the rad.
I would have to say also that I'd go with a C6. I only say that because I know little about the FMX trans. Most who I've talked to have taken it out and put in a C6..
Chris
Never Forget Our Soldiers
If I would swap to a C6 trans, would I need other parts regarding drive shaft, shift linkage and flexplate?
Were special C6 used in trucks or were they the same than in cars?
Where would you buy a good quality remanufactured C6 as well as a converter for our trucks?
Thanks, Roman
Thanks, Roman
- FORDification
- Site & Forum Admin
Another thing I should add: Ford LWB trucks equipped with an automatic have a bolt-on yoke on the transmission for the driveshaft. The car-type transmission will have a slip yoke. I believe you can still use the car-type transmission as long as you have the slip yoke.
____| \__
-O-----O- Keith
My '67 restoration video
-O-----O- Keith
do yall know what those truck yoke's Torque down to??
"Gas' Guzzler fer life" "Southern Pride""It's not what you buy it's what you build"
- cobraF100
swissranger,
As we spoke before about you building an 390 and then you maybe thinking of going with a C6 here's something to look at:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=33615
Chris
