67 f100 4x4 steering question
tybob81
Post by tybob81 »
What are my options on the power assist steering set up on a 67 f100 4x4? Is there any swap to go with a full power steering box and junk the power assist set up? Will a 67-77 bronco w/ps box bolt in?
1968 swb hydroboost, ididit tilt column, Saginaw p/s pump with F series serpentine, all led lights, Vintage Air and painless wiring. 393w, tko600. CV front suspension w/c5 calipers and gt500 rotors. Stock Flexomatic leaf springs with 01 CV 8.8, 3.90 gears and Auburn locker. Custom wood bed floor. Full frame off resto-mod.
tybob81
Re: 67 f100 4x4 steering question
Post by tybob81 »
ImageImage a few pics of it
I dont think any thing just bolts right in.
I put a disc brake front axle and P/S gear from a '78/'79 F150 in mine.
The axle bolts right in but you have to "modify" the frame for the steering gear.
Thats a nice looking truck it would be worth doing it right. :2cents:
tybob81
Post by tybob81 »
Thanks we just completely restored it for a customer. But he didnt do or have us do anything to the factory box. We had a machine shop repair the valve and make us a new shaft for the steering ram. Just wanting to know if there was a easy swap using some other year ford box. the customer now wants to posibly update the box to a latter style to ditch the power assist set up.
fordman
Post by fordman »
heres how my truck is setup. it uses a 2wd drive box on it.
willysrul
Post by willysrul »
I am using a 78-79 Bronco box that is drilled and tapped to run hydro assist.
What is the owners intended use for this truck? You could check with PSC Motorsports to see what system they can build for ya if he wants to keep the power assist but just get a up to date more reliable version. They are pretty pricey but well worth the money from what I have heard.
67 HiBoy - 390/435/TS'd205 HPD60f/FFD60r welded 3.54's 36x12.50x16 TSL radials
50 Willys P/U (project) - 302/435/205 FFD60r
tybob81
Post by tybob81 »
All the truck is going to be used for is cruise nights and ocasional boat duty.
mr_josh
Post by mr_josh »
AFAIK, the early Bronco box and the F-100 manual box are about the same as far as mounting is concerned. Only problem is, they are going for huge dollars because they're rare and rock crawlers like them.
Another alternative is an early-'90s IFS Toyota box. You need a different pitman arm, but they mount almost the same as the F-100 box. I am in the process of doing one of those on my truck, I think it's going to work out pretty well.
Josh
'72 F-100 Sport Custom 4x4
tybob81
Post by tybob81 »
I heard about the toyota swap but didn't know how much involved it was. My customer decided to buy a rebuilt maual box and keep the power assist set up.
Stafford Man
Post by Stafford Man »
Funny, after researching all the options to replace that setup on my 69 4WD I arrived at the same conclusion. I had the valve body, box, and ram re-built by Lares Corp, and found new tie rods and drag link.
tybob81
Post by tybob81 »
We put a new gear box and all new steering linkage on it. Let me tell you it drives like a dream compared to before!! He liked it so much he decided to keep it stock with the power assist.
