Heater core replacement any tips or pictorials
Electrical and Wiring Forum Archives
4x4x4crewcab
Post by 4x4x4crewcab »
While installing my new heater hose today I noticed a little excessive movement on one of the heater core tubes. I have a good idea something let go in there. Any tips on removing or photos of a removed heater box would be appreciated. 1970 f250 heater only no a/c Thanks
Mark
1970 Ford F-250 Crew Cab 4x4 short box
1969 Volkswagen Karmann Ghia
1999 Ford Windstar
1983 Chevrolet Silverado p/u
1990 Lincoln Town Car
1998 Lincoln Town Car
Does your truck need emblems? Check out http://www.onceuponapart.com
fordman
Post by fordman »
sorry i have done one on 68 f100 with a\c what a big blank. so yours should be easier than mine.
Freightrain
Post by Freightrain »
With NO a/c...it's a cake walk!!!!
There are about 10 screws holding the cover on (inside cab), once you take blower motor off, remove screws, the cover falls off and you slip heater core out. If you take your time, it might take 10 minutes to get it apart.
Bump'n along.
heatmiser
re: Heater core replacement any tips or pictorials
Post by heatmiser »
Like Freightrain said "it's a cake walk!!!! "
It's a pretty straight forward job!
With Factory AC ?, now that's another story!
lobuck76
Post by lobuck76 »
If you take the heater box out I would flag the control cables with masking tape and a magic marker. I can never remember wich cable went where. I marked them the last time and it made it go a little quicker.
'71 F-100
71-F-250SC-72-F-250C
Post by 71-F-250SC-72-F-250C »
I also need to replace the core in my truck. Is this where you are talking about taking the screws out of, towards the back?
71 f-250 Sport Custom-frame off in progress..again thank to irjetmachanic. :)
72 f-250 Custom
71 f-100 swb sport custom
03 mach1 mustang
cant forget my thing...haha 74 volkswagon thing.
[quote="ToughOldFord"]
Damn, 7 gallons per mile, obviously FE powered!
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
No, those are on the front....and those are for the blower motor. You need to remove the entire heater box to get to the heater core.
From the engine compartment, remove both heater hoses and the three nuts holding the heater box to the firewall. Drop the heater box down and disconnect the heater control cables, making sure to mark them for correct position and disconnect the electrical connector. Then just pull the heater box out and set it on a workbench. Flip it over to the back side (where the heater core nipples are protruding) and you'll see some small bolts/screws which hold the back cover on. Remove those screws to get the cover off, and voila', there's the core. :D
____| \__
-O-----O- Keith
My '67 restoration video
flyboy2610
Post by flyboy2610 »
Sounds so simple even I could probably do it!! :lol:
Gonna have to one of these days, too.
Red Green
you'd better be right.
willowbilly3
Post by willowbilly3 »
Here is a tip for changing hoses. ALWAYS slit the hose off the heater core nipple and peel it back. I have seen more heater cores ruined from people trying to twist the hose to get it unstuck. :cry:
And if it's on a car with a 4-5 hour flatrate, plan on spending all day, maybe 2 to get it, like on an air conditioned T-bird, Volvo, Subaru, Cadillac ....
Great ideas have always encounter violent opposition from mediocre minds.
67F250CS
Post by 67F250CS »
Hope Im not too late. Here are a couple of my box and the holes where to mount them.
1967 F250 Camper Special
10MPG with key off, in neutral and going downhill!
4x4x4crewcab
Thanks everybody I was a bit busy this weekend but should be ready to tackle this job soon.
Mark
1999 Ford Windstar
cavedweller
Post by cavedweller »
It is a cake walk if you have a lighted shop or do it during the middle of the day. Still not to bad when you start at 5PM when the days are getting shorter in a gravel drive way and finish up by flash light. Mine a 72 f250 no AC. 7 screws for glove box liner, all the rest are 3/16. 3 top the right one goes down into the blower housing and also has blower ground attatched. 4 holding blower motor on housing. 3 just underneath the blower and 2 just to the right of that going up through the housing. The 2 vent cable controls behind the air outlets on the housing are also 3/16. Took 8ft of new heater hose for slicing and dicing. 40 min daylight 60 min flashlight.
flyboy2610
I would remove the heater box, disassemble it completely, and clean all the rust off the metal parts, repaint it, and have it looking like new.
The paints drying on mine as I type this.
(I warned the wife I was going to do a lot of painting in the basement over the winter. She even said I could bake the paint on the metal parts in the oven! :D )
Red Green
4x4x4crewcab
Easy Peezee :D What was I worried about "cake walk" like mentioned above :woohoo: all in all done.
Mark
1999 Ford Windstar
cavedweller
I was able to get by cleaning mine up with Simple Green.
No rust on it. I haven't ask my wife yet if I could bake ford parts in the oven. Although my ex used to make some stuff that kinda tasted like baked truck parts.
