cab marker lights
- 1971ford
cab marker lights
Where would i get some good carb marker lights? Original looking would be a big plus. Just don't want a set where the chrome will flake off after a year...
-Ryan
- 1971ford
- papabug71
Re: cab marker lights
Ryan, this is the best I can do for you if wanting to stay with incandecent lights. Not alot of choices left. Everything is going LED.
http://www.pmlights.com/products.cfm?cI ... 1&pId=1396
You will have to find a vendor. Most truck stops still carry PM stuff. Tractor supply does too. (If you have those in CA?)
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
- 1971ford
Those are nice looking lights! THanks for the info!
Just googled the part number and found this. I think my search is over
http://www.outdoorpros.com/Prod/Peterso ... 3534303737
-Ryan
- papabug71
It was Grote. Looks like they are still around as marketing outfit. The lights they are selling have PM, Truck-lite & KM parts numbers. . .
http://www.grote.com/prodcat/B.html
Matt
Mine since 5/7/'94
I swear you an I have te same tastes Ryan... what type of layout are you drilling in your roof for lights? That's my only thing, I've seen a ton of different ways to do it
-Mike-
ECV 1849
Build>http://fordification.com/forum/viewtopi ... 22&t=68225
69' F250 Highboy 390ci.,NP435,Dana 24,HPD44,D60
67' Dodge Coronet R/T 440ci.4speed,D60, all numbers correct
72' Dodge Dart 440ci.727,D60,10ptcage street strip on meth 10.40s
05' Chevy Tahoe LT loaded for the wife an the baby duty
12' Ford Focus Titanium Hatch Back, Gas saver for the work week
ECV 1849
- 1971ford
Yeah I think we do
I will be drilling this layout
This is the only other layout i've seen on a bump. I don't think it's an original layout.
-Ryan
- papabug71
My in-laws 72 F350 has factory chicken lights. They are spaced evenly, like those in your first pic
Matt
Mine since 5/7/'94
- Mancar1
Here is a pic of mine. I spotted some marker lights hanging on the wall in a local parts place that are just like them and mine could stand to be replaced after 43 years
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
three close together in the center means the vehicle is more than 108 inches wide. the two on the sides are jsut side marker roof lights. being evenly spaced they are just roof / clearance lights.
Good to know fordman thanks
-Mike-
ECV 1849
ECV 1849
- tylerb43
Hey Ryan, did you ever order these and get them installed?
My truck had KD517's on it (not original) when I bought it in '92. I liked the chrome, so I bought the set from LMC and they are huge, just too tall. So I'm thinking either lower profile cab lights (like the ones you're looking at) or nothing at all.
Thanks!
Thanks!
- 1971ford
Nope had to put the little project further down the list after a few problems after a wheeling trip but still plan to order those marker lights linked above and get them on sometime
-Ryan
- jzjames
So whats the deal with the roof marker lights? Did ford have a standard pattern for their placement, or did dealerships come into play?
is there a templete showing how to lay them out? Or are we on are own with thayjzjames wrote:So whats the deal with the roof marker lights? Did ford have a standard pattern for their placement, or did dealerships come into play?
-Mike-
ECV 1849
ECV 1849
