67 F100 Door
67 F100 Door
Found a 69 door to replace my crunched door but the interior door latch is different. Will the door release from my 67 fit the 69 door or do I need a 67 door?
Thx
Thx
- JWW
Re: 67 F100 Door
The doors are interchangeable.
Edit: Note that you cannot interchange the interior handles or arm rests. You can use any year door 67'-72' on these trucks.
Scroll down on this page to see the differences:
http://www.fordification.com/tech/67-72ID_01.htm
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
My project: http://www.fordification.com/forum/view ... &sk=t&sd=a
2004 F150 Crew Cab
Re: 67 F100 Door
the latches are different for the 67 vs the 68-72 door latches. they wont interchange. the only way a door latch will fit to the stricker is to swap sides with a 68-72 drivers side to a 67 passenger side. and viseaversa. the interior hanld mech wont interchange between 67 and 68-72 at all.
Re: 67 F100 Door
Dang... That really limits my options. Guess Ill hold out for a 67 door. Thx guys
- JWW
Re: 67 F100 Door
Good luck. They are rare.wildmtn67f100 wrote:Dang... That really limits my options. Guess Ill hold out for a 67 door. Thx guys
JWW
2004 F150 Crew Cab
2004 F150 Crew Cab
Re: 67 F100 Door
I have a decent door and if your window crank and handle mechanism are good enough to be salvaged from your old door you may be in luck
- bindernut
Re: 67 F100 Door
Where are you located wildmtn67f100 ??
I have a pair I picked up. They are pretty much gutted but the sheet metal is straight save the mirror mount holes. you could re-skin your old ones or swap over the guts if you're close enough.
1971 f100 CS 360/AT
1970 f100 C 302/4spd
http://www.fordification.com/galleries/ ... ?pos=-6153
1969 IH Scout 800 304/AT
"ya know, you're about as useful as Amish tech support."
"The problem with quotes on the Internet is that it is hard to verify their authenticity" - Abraham Lincoln
Murphy lives in my shop and takes advantage of any opportunity he can find.
Law of Mechanical Repair - After your hands become coated with grease, your nose will begin to itch and you'll have to pee.
Re: 67 F100 Door
if anyone finds any more 67 doors i really need some as well
Re: 67 F100 Door
- bindernut
Re: 67 F100 Door
My 67 doors are up for grabs if anyone is close enough to Northern AZ. Could probably ship them but that'll be pretty pricey.
1971 f100 CS 360/AT
Re: 67 F100 Door
well find out how much im up in washington if there in relly good shpe i will py for shiping and wht ever you wanted for them if its under $300 all together
Re: 67 F100 Door
well i jst found 67 in my area going to look at it on thursdy so i will hve to get back to you
- bindernut
Re: 67 F100 Door
randymartinjr wrote:well i jst found 67 in my area going to look at it on thursdy so i will hve to get back to you
Awesome, I'd hate to see anyone have to spend that kind of money for a set of doors. As bad as I want to pass them on and help out, I have a few dollars in the doors myself and couldn't just give them away. Good luck with your find!!
1971 f100 CS 360/AT
- PSB
Re: 67 F100 Door
Hate to revive a stale thread, but I'm in need of some guidance. I searched, but couldn't find anything on point.
After a few years of swapping cabs, doors, and whatnot, I'm currently left with a great 70 camper special cab, a great set of '67 door shells, and usable guts out of a '69 door.
I know 67 door internals were one year only. What do I have to do to get this work with what I currently have?
I was thinking of power door and window kits. Does that simplify or complicate things?
Thanks in advance!
Peter
Thanks in advance!
Peter
1967 F100 Long Bed, 240 I6, 3 speed-on-the-tree
