Attention 67' Truck owners, Knob Inserts
- klk67ranger
Update 7/31/14: Parts are back from bright dip, they look great. I'm not happy with the material I used, it's more milky looking than the originals. I can't get the 5657 alm that Ford used unless I buy a 1,000 lbs of it (not happening). I'm going to use 5052 alm, it has a more chrome look like the originals. At this point I'm thinking around $40 for a kit that will have 10 inserts, installation tool, and instructions. I need to send my sample 5052 parts for bright dip anodize to make sure it looks as close as possible to the Ford ones. Here are pictures of the first proto run using 3003 alm
Korey
Korey
- kf7mjf
Re: Attention 67' Truck owners
i'd be all over that like white on rice!!
i need some as well!
- guerra
- floyd67
let me know how much
1967 f1oo "floyd"
2013 f-150 DD
2005 audi a4 (wife's car)
2013 f-150 DD
- shango
- klk67ranger
This is something that will take some time, but I will move forward. I have no idea how much a kit will cost at this point, depends on batch size, bright dip, and tooling investment.
- pat67shorty
Intriguing.
'67 SWB, 1970 car 390, Edelbrock Streetmaster intake, MSD 6AL, 780 Holley, Hedman headers, 2.5 duals, 3.54 D44 L/S, C6.
- kf7mjf
- colnago
Wow, what timing! I was just going to post a question on where I could find new inserts for my '67 knobs. Yes, I'd be interested!
By the way, a guy at work had some parts made at www.emachineshop.com. Basically, you download their software to draw up the machined item, then order as many as you want, in the material and finish of choice. If you order one, it's kind of expensive, because you're paying for their setup and tooling time, but if you order a bazillion, the price per unit starts going down. Dunno if this is more than you want to do, but you might check them out.
Joseph
Joseph
I'll take two sets,one for Old Blue and one set for Rusty.
1967 Ranger,Short bed,390,C-6,9 inch,4 BBL.,intake,cam,headers,3:55 Posi.,A/C,Power steering,Power Disc Brakes,Automatic trans.DJM dropped I-beams,flipped rear hangers,headlight harness upgrade.ExTang tonneau cover "Old Blue".
http://s508.photobucket.com/albums/s328/BigSxy96/
1967 Base model,352,2bbl.,3 on the tree,short bed,3:25 9 inch "Rusty".
1967 Mustang coupe-show car/garage queen.Small Block,alum. heads,Nitrous,4:11Locker,Areospace brakes "Mystang".
1996 F-250 Powerstroke-Big intake,exhaust,injectors.(Nice Smoke Show) "Big Sexy"
- kf7mjf
When you get an idea of cost, I'll be happy to put down a deposit for pre order. Do all my knobs and my radio.
1967 F-100 Ranger
Sounds worth while. Not enough '67 parts made aftermarket!!! This would be great!
1967 F250 66k original miles when bought in 2012. Original 352 bored and stroked (Oct 13) to 396 cid, Upgrades include Cam Motion solid cam and lifters, C8AE-H heads now flow 220 intake/163-170 exhaust w/o pipes. Current project is a C6 swap in place of the original FMX. 4:10 Dana 60. Truck Custom ordered by original owner in Dark Moss Green over Wimbledon White.
- Mike R
hit me
Theeeeeeere ya go!
In Progress:
'67 F250 Custom Cab Camper Special "Cecil"
In Progress:
