4 pin trailer lights.
72bumbee
Post by 72bumbee »
I hooked my traile house up to move it after an extensive rebuild, and plugged in the 4 pin driving light connector. The lights all worked fine then I pulled the wheel chocks, and went back around, and all the lights were out. I suspect a bad ground or a blown fuse, but can anyone tell me if there is a fuse in the fuse box for that, or do I need to look at the twelve volt converter in the trailer?
I looked at the schematic on the wiring diagrams section and it shows the amperage of the fuses but not the component they go to?
“To succeed in life, you need two things: ignorance and confidence.”
Mark Twain
1972 F-250 Camper Special. 360 A/T P/B AND a DANA 60 Rearend!
Former owner of dads 1967 F-100. It has gone home to the big road in the sky...
Re: 4 pin trailer lights.
If your truck lights are working it's not a fuse in the truck it's probably a ground problem.
It may have been grounding through the trailer bar until you moved it.
72bumbee
Post by 72bumbee »
sorry it took so long, but that was the issue! Thank you!!
Mark Twain
ToughOldFord
Post by ToughOldFord »
72bumbee wrote:sorry it took so long, but that was the issue! Thank you!!
Haaaaa, a five year hiatus for a reply! See, I'm not the only one! :lol: :P
1969 F250 Ranger Camper Special. 390, NP435, 3:73s.
That government is best which governs least, because its people discipline themselves. -Thomas Jefferson
