headliner
- jimmy828
headliner
I'm getting ready to do the headliner in my 69 but have to know how thick the original liner was. The liner was missing when i purchased the truck. I have been checking some materials out at Lowes but did not know how thick i can go with it.
- phantomtruck68
Re: headliner
3/16 of a inch is what my original measured out to. I think you could go up to 1/8 inch with no problems.
Joe
My Phantom truck
1968 F250 4x4
390 FE, bored .030, Crane 272 cam, 600cfm Edelbrock carb.
My Phantom truck
1968 F250 4x4
- jimmy828
Re: headliner
you must meant 1/4. Thanks for the replyphantomtruck68 wrote:3/16 of a inch is what my original measured out to. I think you could go up to 1/8 inch with no problems.
Re: headliner
It's a Masonite type product,perforated. Is that what you are looking for?
Pete's Ponies
Mustang RUSToration & Performance
- jimmy828
Re: headliner
is this product purchased at lowes/home depot?PetesPonies wrote:It's a Masonite type product,perforated. Is that what you are looking for?
Re: headliner
I used 1/8 hardboard is what lowes calls it. Worked great, covered it with duck cloth from Joann's that my wife had. Quick cheap and easy. Of course I had my old headliner as a template.
- Mancar1
Re: headliner
I used wood paneling for mine, stained and varathened it. I also used my old one for a template. Would have been a lot harder without the pattern.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- jimmy828
Re: headliner
I know. That's going to be a problem for me, no template. I guess there will be several do overs on getting a template to trace to whatever i going to use.Mancar1 wrote:I used wood paneling for mine, stained and varathened it. I also used my old one for a template. Would have been a lot harder without the pattern.
Re: headliner
If you have the trim just lay it out and mark it on some cardboard, just cut a couple of extra inches and then set it and the trim back up there and do a final trim. A little more work but you do what you have to do. Mine was so brittle that all it was good for was the template as it was crumbling in my hands as I handled it on removal.
- jimmy828
Re: headliner
Thanks for the tip.Damon23 wrote:If you have the trim just lay it out and mark it on some cardboard, just cut a couple of extra inches and then set it and the trim back up there and do a final trim. A little more work but you do what you have to do. Mine was so brittle that all it was good for was the template as it was crumbling in my hands as I handled it on removal.
Re: headliner
if you still need a template pm me your address and i'' make one for you
- hillcountryflt
Re: headliner
Just pulled the headliner down from my 69 f100. It is pretty brittle and faded. Used to be white. Considering some options myself. What about putting sound deadening material in as well? Anyone done that with success. I have read some issues with products not sticking.
2016 Explorer;
2020 F150
2016 Harley Ultra Limited
2008 Ford Mustang Deluxe V6
2016 Explorer;
2020 F150
Re: headliner
Look into the 'Silencer Megabond' product with Hushmat:hillcountryflt wrote:Just pulled the headliner down from my 69 f100. It is pretty brittle and faded. Used to be white. Considering some options myself. What about putting sound deadening material in as well? Anyone done that with success. I have read some issues with products not sticking.
http://hushmat.com/installation_guides/ ... ctions.pdf
- jimmy828
Re: headliner
I may take you up on the template later. Sorry for the late response.CharlaineC wrote:if you still need a template pm me your address and i'' make one for you
