I've got a stock AM 68-72 radio to install In my 68. I don't care so much to get the radio working. More so I'd like to get the light working to light the display. Anyone know where I can find out how to install it. A PO has hacked up the wiring behind the radio.
Any advice would help. Thx
stock radio installation
- Craigerf100
1964 F-100 Custom Cab Short Bed
1968 F-100 Short Bed
1967 Fairlane 500 Convertable
1967 Fairlane GT/A 289ci SOLD
1950 F-1 Original 239ci Flat Head V8 SOLD
1995 f-150 4x4 Swb 4.9L 5-speed FORSALE
My Build: http://www.fordification.com/forum/view ... &sk=t&sd=a
Re: stock radio installation
I did the same thing, except I have a radio in the glovebox. On the radio there is a single black male plug. That should run over toward the driver side where there will be a plug with three female plugs. Here's a pic of a mustang, but basically the same plug. http://www.mustangmonthly.com/projectbu ... to_04.html
If your wiring is too butchered up you might could just tap into the cigarette lighter's light. I believe it is a small blue wire.
My build thread...http://www.fordification.com/forum/view ... 22&t=67317
- Craigerf100
Yeah that or tap into a wire off the light switch.
- Nitekruizer
The wire for the dash lights, the light for the cigarette lighter and the light for the heater controls is a blue wire with a red stripe. It's controlled by the rheostat (dash dimmer control) in the headlight switch. I hate to cut factory wiring to make splices, but you may be able to plug into it at the cigar lighter or the heater controls if you make a little "Y" using bullet connectors. I hope this helps.
- Craigerf100
K cool ill just do that. Thank you
How did you mount your radio in the glove box? can you post a photo?cole71 wrote:I did the same thing, except I have a radio in the glovebox. On the radio there is a single black male plug. That should run over toward the driver side where there will be a plug with three female plugs. Here's a pic of a mustang, but basically the same plug. http://www.mustangmonthly.com/projectbu ... to_04.html
thanks
jb
I made a bracket to hold the radio to the glovebox.
A piece on top and bottom to hold it. Then, I just cut a hole in
Back of the glovebox to run the wires. I also put an aux
Cable in and ran it through the ash tray to plug up iPods, etc...
Hope that helps
looks good, Thanks for sharing!
