.....weapons of last resort-screw removal
I tried the penetrating oil.....i tried craftsman screw-out.....i tried craftsman screw-out with a reversible drill it has not worked these screws hold on engine covers and the engine to the frame on my motorcycle. my last thought was maybe the japanese reversed the screws so counter clockwise tightens. that turned out not to be true it would have been nice though. I do not know where to go from here. Two of my screws look like dog bowls. everytime I would get resistance it either messed up the drill and/or required me to speed up,then it would just break free and lose traction. short of using a explosive device what can be done?
69 F-100 2wd 360 cid C6
Catapultam habeo. Nisi pecuniam omnem mihi dabis, ad caput tuum saxum immane mittam.
I have a catapult. Give me all the money, or I will fling an enormous rock at your head
- 72hiboy4x4
- Location: As far away as I can be from Wa state, without crossing the Mississippi
!. use a screw extractor/hammer driver. put a phillips head in the end, place it on the screw and whak it a couple times. worked all the time on my bikes when I was a kid. (recommended)
2. carefully cut a slot in the end of the screw for a flathead screwdriver, tap a large flathead screwdriver in the slot with a hammer. Now, while holding the screwdriver with vice-grips, turn the screwdriver and at the same time,hit the end with a hammer. easier with 2 people. (did that make sense?)
In life many men take the path of righteousness, some take the path many others follow (G.M. owners, for example), some take a more arduous path, some a simpler path. I, sir, took the PSYCO-PATH!!
re: .....weapons of last resort-screw removal
most of these are recessed into the engine body. on one at least, there is hardly anything left of the head....its more like a rim and a hole hollowed out by about a 4th of a inch. I am unsure if i can cut anything. I have a 12 volt cordless drill and the standard set of screwdrivers and sockets. I have no idea what my dad may have. how would you cut a screw?
- 1970F250
well the screw extractor-spiral shank type worked.
- mrung0wa
I have a set of left-handed drill bits and I always try to use them first!
If those don't work I have a choice of either a 3/4" Impact wrench (forward or backwards it doesn't matter it will come off...) or a 20lb sledge hammer.
I like to have choices.
Lawrence
Lawrence
http://www.fordification.com/galleries/ ... ?pos=-2746
FOR SALE: 64 Galaxie 390HiPo C6 (Project Car)
SOLD! 69 F100 Contractor SPECIAL 300 I6 "Jethro"
01 BMW 325i 4DR E46(Wife's car)
03 EXPEDITION XLT FX4(2WD/AWD/4WD) 5.4L K&N FipK
"I beat my head against the wall, Because it feels good when I stop."
i finally got them all out. but the cover still will not move. guess i'll drop 60 for the factory manual
- binder56jd
oh no not the directions
jd
"Sell crazy someplace else. We're all stocked up here" — Jack Nicholson, As Good As it Gets
now serving #235
"the only way to believe in the American dream is to be asleep"--GC
How much easier it is to be critical than to be correct. - Benjamin Disraeli
now serving #235
Is there a special set for allens head stuff?
- mrung0wa
What are alien heads???
Lawrence
Lawrence
get my terms mixed up...they were hex head
- mrung0wa
FYI: It's just like a "Phillips head" and "Cross head" screw or screwdriver. Mr. Phillips invented/patented the Cross head but unless you had worked out a deal with him (A long time ago) you couldn't use his name.
The "Allen head" and "Hex head" relationship has a similar history.
Just more useless triva...Worth the same as a free cup of coffee...
Lawrence
Lawrence
