![Image](http://i9.photobucket.com/albums/a75/cghstrojan08/1968%20F100/IMG_20140526_190708_235_zps21s1hmoz.jpg)
Wiring from radio
- cghstrojan08
Wiring from radio
Is this plug for the speaker that goes under the dash? Mine speaker is missing and I am guessing that is what it goes to. Any good source for a replacement? The truck has the original AM radio but with an added FM receiver. Would love to get some tunes going.
ROBERT
Member #1076
1968 F100 SWB 360
1969 F100 LWB 360 "Ol' Blue" - Sold
1976 F350 Trailer Special, Extended Wheel base, 460
http://s9.photobucket.com/albums/a75/cg ... ld%20Blue/
![Image](http://i9.photobucket.com/albums/a75/cghstrojan08/IMG_2236.jpg)
![Image](http://i9.photobucket.com/albums/a75/cghstrojan08/ford.jpg)
Member #1076
1968 F100 SWB 360
Re: Wiring from radio
Yes that's the speaker wire from the radio. I don't see the speaker nor the speaker bracket. Do you have the bracket anywhere? I see the hole where the bracket goes but no bracket.
1964 f100
292 yblock
1969 Ranger
Loving all ford vehicles
292 yblock
1969 Ranger
- cghstrojan08
Thanks. Nope, no bracket unfortunately
ROBERT
Member #1076
1968 F100 SWB 360
Member #1076
1968 F100 SWB 360
- cghstrojan08
Anyone happen to have a picture of how the original mounted?
ROBERT
Member #1076
1968 F100 SWB 360
Member #1076
1968 F100 SWB 360
First install speaker bracket, then speaker, then radio.
Are you asking about the speaker bracket mounting? If so, I don't have a picture but the bracket at one end has a flat tab that slides in the
hole you can see in your picture. The other end has a tab with a screw hole that mounts with a screw at the top area of your radio hole.
First you put the bracket in the hole at firewall, set the speaker on bracket "correctly" then raise into position and secure with screw.
I have the bracket if your in need of one, I might even have an original speaker as well.
I can try and get pictures for you on mounting this, or at least pictures of bracket and speaker.
![Image](http://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=258443&.jpg)
1964 f100
292 yblock
1969 Ranger
292 yblock
1969 Ranger
- cghstrojan08
Awesome! Thanks for the picture. PM sent
ROBERT
Member #1076
1968 F100 SWB 360
Member #1076
1968 F100 SWB 360
