seat belts arrived
Mancar1
seat belts arrived
Post by Mancar1 »
Got my new seat belts and they are nice. will post a pic and what I think of them after install. :thup:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Corkwheats
Re: seat belts arrived
Post by Corkwheats »
Did you get the black ones?
That's probably what I'll end up doing.
71 Ranger XLT LB 2WD
Tilt Steering, West Coast Mirrors
390, 9.5-1 C.R., Holley 600, D2 Heads, C-6
Custom Grind Oregon Cam
Flotech Headers, 2.5" Duals w/H-Pipe
Mancar1
Post by Mancar1 »
Corkwheats wrote:Did you get the black ones?
Yes the black ones. That way if I change the truck interior color they will still look right :thup:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Mancar1
Post by Mancar1 »
Well the 3 point seat belts off E-Bay from Welder Joe's did not work out for the 68. The retractable mechanism had to be mounted at a 90 which doesn't work for my application. when mounted, as I need, it stays in the locked position.
Guess I will ship them back and try another. Thinking on just getting a new custom seat with integrated belts.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
CrypticRacer13
Post by CrypticRacer13 »
I followed Robroy to the T with his belt install.
http://fordification.com/forum/viewtopi ... =6&t=50489
Worth the read for sure even if you dont buy the same belts
-Mike-
ECV 1849
Build>http://fordification.com/forum/viewtopi ... 22&t=68225
69' F250 Highboy 390ci.,NP435,Dana 24,HPD44,D60
67' Dodge Coronet R/T 440ci.4speed,D60, all numbers correct
72' Dodge Dart 440ci.727,D60,10ptcage street strip on meth 10.40s
05' Chevy Tahoe LT loaded for the wife an the baby duty
12' Ford Focus Titanium Hatch Back, Gas saver for the work week
Mancar1
Post by Mancar1 »
I was just a little frustrated. I will use the proper L brackets so the belts will mount properly :thup: Just needed to step back and do another project then come back to the belts. :lol:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Calfdemon
Post by Calfdemon »
CrypticRacer13 wrote:I followed Robroy to the T with his belt install.
:yt:
I also did my install the same way as Robroy... I bought my belts through Seatbeltsplus.com including the extra mounting hardware and installing them in my 72 was a breeze. I will be using the same belts and another set of 3 for the crew cab.
If you just need the brackets, I believe Seatbeltsplus.com has a bag of mounting hardware that you can buy for like $5.
It should have everything you need to get your belts installed: http://www.seatbeltsplus.com/product/FHD-1046-1.html
They also have other kits, and just the L bracket if that is all you need: http://www.seatbeltsplus.com/category/S ... sions.html
-Rich
Current toys -
Former toys -
