A/C
67f100customcab
A/C
Post by 67f100customcab »
I have had a 67 f100 truck for a few years now and i just got around to restoring it will a 68-72 ac fit a 67 truck?
bluef250
Re: A/C
Post by bluef250 »
OEM AC, no without cutting dash, or aftermarket, yes.
fordman
Re: A/C
Post by fordman »
Yes they will bolt right in. U do not have to cut dash. The heaterhose holes and ac drain holes will have to be put in firewall though. I think new holes need made.
Mach428
Re: A/C
Post by Mach428 »
A 68-72 AC unit will bolt in but keep in mind that the factory AC unit uses the heater / blower controls in the dash, which are levers in 68-72 and pull knobs in 67. I don't know how you would integrate the controls of a 67 to work with the 68-72 unit.
fordman
Re: A/C
Post by fordman »
Mach428 wrote:A 68-72 AC unit will bolt in but keep in mind that the factory AC unit uses the heater / blower controls in the dash, which are levers in 68-72 and pull knobs in 67. I don't know how you would integrate the controls of a 67 to work with the 68-72 unit.
good point. U would have to cut dash for the controls.
guhfluh
Re: A/C
Post by guhfluh »
If the cables from the 67 are long enough and the blower resistor a 2 speed, the 67 controls should work. The 67 has 3 cables, just like the 68-72 does, but they may be too short. You could possibly still wire the 2 speed switch to a 3 speed blower resistor also I believe, you'll only have 2 speeds though, and you'll have to get creative on the A/C compressor turn on wiring. If you have the style that has its own A/C knobs on the unit, I think you should be able to make it work easily.
I am STILL in the process of trying to fit my Custom Auto Air Perfect Fit system into my 67, and it's taking a lot of head scratching and customizing to get it to work with the factory controls, as well as seal off the rain water from the passenger vent hole where the A/C lines go through.
'67 F-250 Crew 2wd 300ci, T-170/RTS/TOD 4-speed overdrive
'96 Dodge Ram ECLB CTD
'99 Dodge Neon ACR 2dr - 10.64@130 (Sold)
'05 Infinity G35 Sedan
