What is this hole the the dash for?
- jimmy828
Re: What is this hole the the dash for?
carb choke cable. ( manual choke)
- jimmy828
here's a pic
Thanks.
Someone installed the choke knob by the ingition switch, no biggy got lots of patching to do on this anyway.
- 1970FordTK
Thats the spot the emergency flasher switch knob is on my 1970 in my cab.
My e flasher mounts in the glove box.
- duaneo
The switch for the cargo light is also mounted to the right of the steering column.
Cheers,
Duane.
Cheers,
Duane.
- jimmy828
Did that cargo switch take the place of a manual choke for a truck that had automatic choke ?duaneo wrote:The switch for the cargo light is also mounted to the right of the steering column.
Cheers,
Duane.
- Kurt Combs
My 1972 F-250 has the emergency flasher knob in that location.
Kurt
1972 F-250
1972 F-250
- shortbedCUSTOM
Are all these holes the same diameter? I no longer run a manual choke so that spot is vacant and I would like to install an emergency flash knob.
-carlos
- shortbedCUSTOM
-carlos
- Mancar1
That should be doable.shortbedCUSTOM wrote:Are all these holes the same diameter? I no longer run a manual choke so that spot is vacant and I would like to install an emergency flash knob.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- Nitekruizer
To answer your question, no not all of the holes are the same size. It depends on what the hole was for. All of the Choke cable holes should be the same size though.shortbedCUSTOM wrote:Are all these holes the same diameter? I no longer run a manual choke so that spot is vacant and I would like to install an emergency flash knob.
My '69 had the switch in the glovebox too. I moved my switch to the Choke knob opening, using a switch from a '70-'72. It's a perfect fit.
P.S. You'll have to unwrap the underdash harness and extend the White/Blue stripe wire by about three feet. It's the only wire that was too short to reach the new location. I hope this helps.
- HIO Silver
I installed a 12 vdc power port for the E-Street EFI's tablet. I'm gonna add an oil pressure gauge and be done.
From Edelbrock's website:
