1968-72 FACTORY A/C DRAIN HOSE LOCATION?
CHUCK4850
Post by CHUCK4850 »
I'm installing a 1968-72 factory A/C unit in my truck, and I need to drill a hole in the floor for the condensation drain hose. Does anybody have a truck that originally came with A/C that can check the location? I'm thinking there is probably a dimple where the floor should be drilled, but my floor is covered with Dynamat and bedliner, so I can't see it.
Chuck
CHUCK4850
Re: 1968-72 FACTORY A/C DRAIN HOSE LOCATION?
Post by CHUCK4850 »
Thanks!
2wdwyatte
Post by 2wdwyatte »
Since you say that there is dynamat on the inside, check the firewall from the engine compartment and there should be bump or dimple (raised) on the fire wall for the a/c hoses and on the front side of the driver side radiator support for the receiver/drier and condensor hoses. I can't remember if there is one for the drain hose. But once you install the factory underdash unit you can easily orientate where to drill.
