Coolant in carpet near passenger's door.
Pat Crash
Post by Pat Crash »
Today, I lifted up my rubber mats and say what appears to be coolant soaked into the carpet near the passenger's door. I had the heater core replaced about 6 months ago as I had this problem for a while. I just thought it was fixed, so I never checked it again. I don't seem to be losing any coolant as the level seems just fine. Anybody else experience a thing like this?
1971 Ford F100 Ranger XLT Long Bed — 360 with C6 Automatic — 9" with 3.00 Gear Ratio
HIO Silver
Re: Coolant in carpet near passenger's door.
Post by HIO Silver »
Does it smell sweet? Then it is likely coolant...
But it has been raining in SD, right? Could be a leaking windshield seal, overflowing footwell vents' or rust-through of the cowl.... oh a bad wiper shaft seal could also lead to water intrusion.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
If it's coolant, i.e. antifreeze, it has to be coming from the heater core or the hose connections to the heater core. That's the only place coolant enters/exists in the cab. Maybe a loose hose clamp? Either that or your new heater core has sprung a leak. :(
Pat Crash
Post by Pat Crash »
I don't believe the issue is the rain as this has been going on for a while, and it never seems to dry up. I smelled the liquid, but I couldn't really tell by the smell if it was coolant—that usually smells like pancake syrup to me. The color seems to be green, but then again I do have green carpet. I thought a picture might help. The rusted out area in the photo is damp. So this definitely didn't happen overnight. Does anyone know (or has anyone seen this before) what would cause this specific area of the right passenger interior panel to rust out like that?
tac
Post by tac »
That is where the bottom of the fresh air duct is spot welded. It could be full of dirt blocking the drain hole and holding moisture.
76Kroh
Post by 76Kroh »
My 68 had a leaking heater core in that area. Must have been for years because the floor pan is rusted from the inside to the point of making a small hole. Found this out when I pulled up the rubber may this weekend Getting ready to do carpet. Guess I will be replacing the floor pan first. :doh:
1968 f100 LB 360 4-speed manual :help:
Pat Crash
Post by Pat Crash »
tac wrote:That is where the bottom of the fresh air duct is spot welded. It could be full of dirt blocking the drain hole and holding moisture.
I will check into that.
Looks like I can't rule out the heater core that was just repaired.
tac
Post by tac »
I think you have 2 issues. The heater core leaking will make the carpet wet but shouldn't cause the rust and junk behind the fresh air vent will cause the rust in that area.
Pat Crash
Post by Pat Crash »
tac wrote:I think you have 2 issues. The heater core leaking will make the carpet wet but shouldn't cause the rust and junk behind the fresh air vent will cause the rust in that area.
Thanks tac
