Hey All,
I'm putting together a 67 and have been using a 72 parts truck as reference. I see on the cab of the 72 there is a door stop/bumper just below and to the inside of the door latch post. The cab of the 67 doesn't seem to have (or had) the hole for the bumper. Was my body guy a bit over zealous and was the hole welded/filled? Or is this another 67 difference? Even if they are not 67 correct is it a good idea to use them? I am using 68-72 doors if it matters (previous owner had swapped out the 67 doors )
Thanks in advance!
1967 door stop/bumper
Re: 1967 door stop/bumper
no, 67 does not have the door bumper. In my opinion it is not needed. New door seals and correct door adjustment does the job.
Build thread:
http://www.ford-trucks.com/forums/12052 ... build.html
