Light switch removal
Madman
Post by Madman »
Been a very long time, so can anyone refresh my memory on how you remove the light switch assembly from the dash? Thank you
""Never shoot a large caliber man with a small caliber bullet."
2017 Ford Raptor
1948 Willys CJ2A w/ Ford Flathead V-8
1975 Ford Bronco
jimmy828
Re: Light switch removal
Post by jimmy828 »
Use a flathead screwdriver to press down on little tab on top of switch behind dash and at the same time pull on knob to pull out.
Madman
Post by Madman »
jimmy828 wrote:Use a flathead screwdriver to press down on little tab on top of switch behind dash and at the same time pull on knob to pull out.
Knew it was something along those lines, thank you much!
2017 Ford Raptor
1975 Ford Bronco
