Hole in dash
Coolmee1
Hole in dash
Post by Coolmee1 »
I have a hole in my dash between the light switch and the brake light it's a 1969 f100 camper special. It wasn't drill out its from the factory it has a small notch in it. Is this where the aux tank switch goes? Mine was removed by my uncle and he's on longer around so I don't know what it looked like I've seen the under dash setup for the aux tank switch. Love this site thanks in advance
Mancar1
Re: Hole in dash
Post by Mancar1 »
Yes that sounds like that was what it was.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
