Hi. I was wondering if anyone could help me, I have a 1972 f250 and for the past few weeks I have been having trouble shifting my truck into gears, especially trying to shift it into park when I stop the truck.
Today I went to start my truck and tried to use automatic shifter attached to steering wheel and it just snapped off at the base. It's a white metal that has broken which goes around the steering column... does anyone know what this part is called and if I can easily fix this? Thanks for your help...
My gear shifter snapped
- HIO Silver
Re: My gear shifter snapped
Gear selector arm.
.. column has to be disassembled and the arm replaced.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
Are you talking about the shift collar http://dennis-carpenter.com/column-gear ... tab=trucks or the arm itself http://cgfordparts.com/ufolder/fordpart ... =CODZ-7210 ? Here's a write up on rebuilding your column http://www.fordification.com/forum/view ... hp?t=72274
