Another idea for a headliner...hope it helps someone out!
Madman
Post by Madman »
I am a bit disappointed in the price and shipping cost of original headliners, I believe I have a better idea than original, that is if you are not trying to do a concourse restoration.
I found a great substitute headliner material. I got this piece of Vinyl at home depot for $22. It is 4x8 and white, but I believe it can be painted. It was advertised as shelf bases, but it is perfect for a headliner!
I used the trim to rough outline the shape and size, cut it big to allow trimming to size in place.
I basically screwed it up in the overhead in the center portion and worked outward, screwing it down and trimming it in place.
Final product I believe looks good!
""Never shoot a large caliber man with a small caliber bullet."
2017 Ford Raptor
1948 Willys CJ2A w/ Ford Flathead V-8
1975 Ford Bronco
Re: Another idea for a headliner...hope it helps someone out!
Cool! Thanks for the tip! :thup:
Cool, looks good. I went with a sheet of white aluminum flashing for kitchens and while it looks nice, it's rattle sometimes.
eggman918
Post by eggman918 »
I used dog eared cedar fence planks that i planed down to 1/4" thick in my crew cab
Steve
Madman
Post by Madman »
The cedar looks sharp! Bet the aluminum does as well!
2017 Ford Raptor
1975 Ford Bronco
crazyhorse
Post by crazyhorse »
Mr Madman, thank you for good information.
Looks good, easy to install & cheap . :thup:
Jacksdad
Post by Jacksdad »
Awesome idea. Mine (being from a motor home with a walk through) has a big hole cut in it unfortunately. I found a complete set of trim pieces but no decent headliner, so I'll have to give this a try.
Thanks for the tip :thup:
tnab1970
Post by tnab1970 »
We used a piece of 1/8" hard board from Home Depot. Used the old head liner for a pattern. Worked great and paintable. Cost like $20 , took about 1 hour tops to make. Cut out with table saw and jig saw.
Bullitt74
Post by Bullitt74 »
I used that stuff on my foundation wall in my garage (overtop of 1" foam insulation). It is pretty nice to work with, and cleans very easily.
Great job on the headliner!
Steve F.
Red Deer, Alberta, Canada
8)
