Headliner.paint color
1968f250429
Post by 1968f250429 »
Does anybody know what the greyish color used on the perforated headliners is called? Can it be obtained as I'm getting a headliner from a member but he sprayed it flat black. I may be respraying it if I can get the right color. Any help would be appreciated. Thanks in advance to all.
basketcase0302
Re: Headliner.paint color
Post by basketcase0302 »
Busboy
Post by Busboy »
I matched mine up on my 67 to a "butternut" from Home Depot. I'll get a part # this evening if you'd like.
1967 F-100 4x4 custom cab.
Mach428
Post by Mach428 »
You didn't say what color interior you have but most that I've seen, including mine are a beige color. Nevertheless, you can buy an exact color rattle can for the interior from NPD. The Mustangs shared a lot of the same colors. Mine was a perfect match
Busboy
Post by Busboy »
I used this and I got it at home depot. It was an exact match to the headliner in my 67.It is called "putty.
1968f250429
Thanks , I'll go by the depot and see what I can find.
