Hello
Somebody here use spark plug wires 8mm moroso, taylor,magnecor ? good brands?
thanks
Spark Plug Wires 8mm
Re: Spark Plug Wires 8mm
I ran FMS ones before they were FRPP and you can't go wrong with Autolite wires. I'd avoid Accell and the other seem expensive for your needs
- HIO Silver
I use Pertronix wires. Works great and appears period correct.
I bought Moroso 8mm peformance for my Fairlane and they work great with very high quality.
- Manny
Have a set of taylors on the red bronco that are great. For all the rest of the time i am very guilty of running the for 9mm wires.
- Jacksdad
I've used Accel Superstock 8mm wires for years on any vehicle that runs a Supercoil. I learned my lesson when I fried a store bought HT lead late one night, finding one end completely charred. At the very least, I run one as the king lead from the coil to the distributor as it gets hit with every spark.
But that said, my bump was getting harder to start, so I investigated and found this...
To be fair, it's been on the truck for a good few years and is ungodly long because I relocated the coil to the fender. It's been fine since I trimmed it and put a new terminal on it.
