Leaky tranny
1guydude
Leaky tranny
Post by 1guydude »
So my transmission c6 is leaking i think from where the kickdown brackett mounts to. Is this possible or should i be looking at other places. Gonna tighten it.all up a bit more and see if that helps.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
2014 audi tt Quatro s
Braaaaap!
69Ford
Re: Leaky tranny
Post by 69Ford »
I had a leaky tranny replaced the pan gasket a couple times. It turned out to be a leak in the O ring of the tranny dipstick tube. C6
basketcase0302
Re: Leaky tranny
Post by basketcase0302 »
"1guydude"]So my transmission c6 is leaking i think from where the kickdown brackett mounts to. Is this possible or should i be looking at other places. Gonna tighten it.all up a bit more and see if that helps.
D
Yes this is a very common place for our Ford automatics to start leaking. It's called the "selector shaft" (which the kickdown bracket and shift linkage actually hook onto).
There is a seal about 1/2" inside the aluminum casing there, (that seals around the selector shaft). Part #7B498 behind the turn signal switch in this image.
As far as I know there is no way to replace that seal without dropping the pan on the transmission / removing the valve body / then removing the selector shaft and replacing the $5.00 seal. I'd source out a written quote from a local tranny shop on this repair. And don't run the tranny long low on fluid or you'll be sourcing out a rebuild on the transmission! :(
Last edited by basketcase0302 on Tue Sep 05, 2017 5:00 am, edited 1 time in total.
1guydude
Re: Leaky tranny
Post by 1guydude »
Well dang. Not what i wanted.to hear but what i wanted tk hear. Thanks guys. Ill have to get the truck to a tranny shop down the road and tackle both those.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
Re: Leaky tranny
Easy DIY fix. A trans shop will charge at least an hour labor to replace the seal and o ring.
1guydude
Re: Leaky tranny
Post by 1guydude »
Well mr bobby ford. I have a rear seal i think so i might just try and tear into it and diy fix it myself. We will see
Thanks all
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
Jacksdad
Re: Leaky tranny
Post by Jacksdad »
Just reading this after cleaning up the oil leak in front of the complex before the landlady see it :D
In my case, I'm pretty sure the front pump seal on my C6 is getting ready to lay down and die (if someone hasn't already administered the last rites while I wasn't looking). The poor truck sits for such long periods, I'm sure all the seals are hardening up.
1guydude - if it makes you feel any better, at least you won't have to pull the transmission to fix your leak :o
