9" bearing and seal help
BayStYAt
Post by BayStYAt »
I have a 71 and I need to change the bearings and seal. I have the small bearing rear end. I need to replace one of the housing bearing ends. Is it possible to replace one?
Also anyone have the correct part numbers for the bearings and seals?
thanks everyone
Busboy
Re: 9" bearing and seal help
Post by Busboy »
Yes.
1967 F-100 4x4 custom cab.
I like to buy my 9" parts from these guys https://www.currieenterprises.com/CE-8000.
BayStYAt
Post by BayStYAt »
Awesome thank you. There are 2 axle gasket per side. Are they the same? or do I need 2 different gaskets?
thanks again
BayStYAt
Post by BayStYAt »
awesome thanks.
are these the axle gaskets I need?
Fel-Pro-55001-Axle-Flange gasket
Fel-Pro 55035 Axle Flange Gasket
BayStYAt
Post by BayStYAt »
could I use Gasket Maker?
Busboy
Post by Busboy »
yes
