Hi guys,
I want to change the fluid of my tranny including empty out the converter and sealing up a leaking transmission cooling line on the radiator. Do I have to "bleed" the transmission after that, especially when I have disconnected one transmission cooler line for some time to seal it up? Or just let it idle, shift trough all gears and P and N and that's it? Does a C6 bleed itself by operating?
Thank you
Bleeding of automatic transmission necessary?
- timachone
Tim
1970 Ford F250 360 FE 2V C6
1973 Ford Mustang Mach 1 351C 4V 4-speed
2012 Ford S-Max 2.0 EB AT
2017 Skoda Fabia Monte Carlo MT
Re: Bleeding of automatic transmission necessary?
No bleeding necessary, it "self bleeds" by purging any air into the trans pan which is open to atmospheric pressure.
1967 F-100 4x4 custom cab.
- timachone
Perfect - thank youBusboy wrote:No bleeding necessary, it "self bleeds" by purging any air into the trans pan which is open to atmospheric pressure.
Tim
As noted above, no bleeding is necessary. The reason, as implied above, is that the fluid system is not a closed system like brake systems. Just like the engine, the transmission, transfer case, & rear end are all open systems.
mmerlinn (http://mmerlinn.com/catalog/makeridx.htm)
"People who are careless and sloppy writers are usually also careless and sloppy at thinking. Answering questions for careless and sloppy thinkers is not rewarding." - Eric Steven Raymond
- timachone
Thank you for the (technical) addition! Good to knowmmerlinn wrote:As noted above, no bleeding is necessary. The reason, as implied above, is that the fluid system is not a closed system like brake systems. Just like the engine, the transmission, transfer case, & rear end are all open systems.
Tim
