Power steering pump pulley
BigAl47
Post by BigAl47 »
What is the correct size pulley should be used. 72 f250 360 w/Ac
Also where can I get one
Thank You
jp2005
Re: Power steering pump pulley
Post by jp2005 »
Honestly ive seen many different sizes depending on if they are after market or factory installed. Any standard pulley will work as along as the tensior holds the belt tight. :wink:
Thanks JP! Ms. Cordova is a factory 1969 Ford F100 Ranger with a 390, Front disc brakes, Cordova copper orange, behind the seat box
BigAl47
Post by BigAl47 »
Thank You for the reply it was helpful
jp2005
Post by jp2005 »
BigAl47 wrote:Thank You for the reply it was helpful
:wel: that's why we are here! :wink:
