Dana 24 thrust washer thickness???
1972 f250 Dana 24 transfer case, can anyone by chance give me the specs on the thrust washer between the front driveshaft output shaft bearing and case?? I have the breakdown and it only gives the OD. I’m looking for the thickness. In the Dana 24 breakdown it’s part # 330278. Or if anyone has a spare I could purchase??? Thanks
Re: Dana 24 thrust washer thickness???
I would try reaching out to Dana themselves as I remember getting the info on my EB driveshaft yoke from them years ago and they were very helpful.="Zrt1" 1972 f250 Dana 24 transfer case, can anyone by chance give me the specs on the thrust washer between the front driveshaft output shaft bearing and case?? I have the breakdown and it only gives the OD. I’m looking for the thickness. In the Dana 24 breakdown it’s part # 330278. Or if anyone has a spare I could purchase??? Thanks
I would try reaching out to Dana themselves as I remember getting the info on my EB driveshaft yoke from them years ago and they were very helpful.basketcase0302 wrote:="Zrt1" 1972 f250 Dana 24 transfer case, can anyone by chance give me the specs on the thrust washer between the front driveshaft output shaft bearing and case?? I have the breakdown and it only gives the OD. I’m looking for the thickness. In the Dana 24 breakdown it’s part # 330278. Or if anyone has a spare I could purchase??? Thanks
https://danaincorporated.gcs-web.com/sh ... contact-ir
