Spare parts differential Dana 60 axle
F250_71
Post by F250_71 »
Hello folks,
First of all, I wish you happy holidays. I have a question about the Pinion Gears on my Dana 60 D0TA-AS axle. I took it apart in the summer and cleaned the differential and axle tubes. Since I couldn't find any spare parts for the 16 spline side gears at Rockauto, I searched E-Bay and found and ordered 2 more side gears with the item number D0TZ-4236-B. I also ordered the required washers with the item number E7TZ-4228-A, which unfortunately don't fit. And unfortunately the two Pinion Gears with the item number C9AZ-4215-A don't fit either :( . I picked out the item numbers on this homepage. Can anyone of you help me to find the correct item number?
Thank you very much in advance.
Manuel
1971 F250 Sport Custom Camper Spezial 360cui
