1967 F-100 project
Tregs
Re: 1967 F-100 project
Post by Tregs »
That's an Awsome job you have done I will be keeping a close eye on this one. good luck with the rest of the build
67nukeford
Post by 67nukeford »
Well, finally able to get some time for truck work. I finished up the dolly I'm going to use to work on the cab. I'll bring it home this weekend, hopefully, to replace the front mounts and cab corners. I'm thinking about pulling the cowl also.
Pat 1967 F100 4WD
LINK TO PROJECT THREAD
:http://www.fordification.com/forum/view ... &sk=t&sd=a
goldies67
Post by goldies67 »
nice work! im looking forward to more updates and pics!
:thup:
1967 f100 styleside
JWW
Post by JWW »
Great progress!
Did you put any rubber spacers in between your leaf springs when you put them back together? I'm debating on doing that.
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
FormerMarine1981
Post by FormerMarine1981 »
Glad to see you back at it. I think it would be cool to put a dent dash into a bump.
What we do in Life, Echoes in Eternity
67nukeford
I think it should work. I did finally get the 89 F-250 that the 351W and ZF-5 5 speed and TC are coming out of this weekend. It was a steal at $550.
Pat 1967 F100 4WD
67nukeford
JWW wrote:Great progress!
Yep, got some from the local suspension shop, along with the new clamps.
Pat 1967 F100 4WD
JWW
Post by JWW »
Would you care to take a picture of where you placed the spacers? Thanks
JWW
2004 F150 Crew Cab
67nukeford
I'll do it next time I'm at my brother's place, that's where the frame is at right now. I'll double check my pics, though, and see if maybe I have a close up of the springs.
Pat 1967 F100 4WD
Joshpow
Post by Joshpow »
Looking good.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
http://www.cardomain.com/ride/2972100
JWW
Post by JWW »
67nukeford wrote:I'll do it next time I'm at my brother's place, that's where the frame is at right now. I'll double check my pics, though, and see if maybe I have a close up of the springs.
If it is no trouble. I appreciate it.
JWW
2004 F150 Crew Cab
67nukeford
Here are a few pics of the 89 I'm getting the engine/tranny out of. Not sure if I'm going to use that factory EFI, or go to an aftermarket, Depends on how much of a pain it would be to use it, so I'm saving everything off of it for now. The only thing missing off of the motor is the alternator and it's brackets. I'll have to get another one, I want to use that serpentine belt drive.
Pat 1967 F100 4WD
67nukeford
Here is the cab, ready for it's trip to the house. Hopefully get it home Sunday.
Pat 1967 F100 4WD
67mann
Post by 67mann »
67nukeford wrote:Here are a few pics of the 89 I'm getting the engine/tranny out of. Not sure if I'm going to use that factory EFI, or go to an aftermarket, Depends on how much of a pain it would be to use it, so I'm saving everything off of it for now. The only thing missing off of the motor is the alternator and it's brackets. I'll have to get another one, I want to use that serpentine belt drive.
I've got an 86 EFI(351W)laying around...maybe it would have been better to use that :hmm: than rebuilding 390 :nono: got have the FE :P but I do wonder if I can make use of anything of it :?
Your comin along looks good :thup:
67nukeford
I was going to put a 390 in this truck, but since I plan on driving this a lot, I decided to go this route. I have a Super Duty for pulling stuff, and I'm not making a race truck, so the 390 will go in another toy, maybe a Fairlane!
Pat 1967 F100 4WD
