I am looking for ideas for a regular, normal, nothing crazy, sound system. Since i had some trouble finding lots of pictures i figured i would consolidate the pictures i found on one thread.
If i borrow your pictures i hope you dont mind...I will try to add links to the pictures original locations for some authenticity.
First thread http://www.fordification.com/forum/view ... &sk=t&sd=a
[/quote]
Second Thread http://www.fordification.com/forum/view ... w=previous
There is also something mentioned of a Volvo kit in this thread? I wounder what year and model?
Third Thread http://www.fordification.com/forum/view ... a&start=15
This is what I did two 6x9s an two 6 1/2 mini subs
One thing to remember about mounting any speakers in the doors, if you use the foam baffles, the speakers will be more protected from moisture, and the sound is much "cleaner". http://www.crutchfield.com/p_237XT65/XT ... ml?tp=2809
Fourth Thread http://www.fordification.com/forum/view ... p?p=391755
Fifth Thread http://www.fordification.com/forum/view ... a&start=15
Okay here is the USA stereo from Custom Auto.
It is very functional, looks great and sounds amazing! The AUX cord comes out through the glove box. It gets compliments all the time.
Here is the passenger side speaker under the dash on a custom mount, you cant see it at all from the seat.
Here is the drivers side under the dash, also on a custom mount, it barley fit, but it did It is also completely out of sight.
Here are the two 6X9's behind the seat, they are in custom boxes, and restricted the seat sliding back by about an inch or two.
Here it is with the seat back. It looks good and sounds great, it will completely cover the engine and road noise.
This is the best part, the doors were not touched, neither was the dash, but it has totally modern sound with great base and AUX input.
here is what I did with my headliner. They are 6.5s and fit pretty good. I have 6x9s in my door panels also. I thought about the kicker panel but decided the door panels would be easier to fix if I ever changed my mind. All together it sounds really good.
this is where I put my speakers..
Sixth Thread http://www.fordification.com/forum/view ... &sk=t&sd=a
here's the pics i promised
this is the dash
and the speakers in the B pillars
[url=http://g.imageshack.us/g.php?h=73&i=img5539ug7.jpg]
"BiggDogg"Here's what I recently did:
I picked up the JVC stereo at Walmart for $97- it has 200 watts of power, a detachable faceplate, direct plug in for ipod, and a remote. Add to it two Sony 5.25" 4-way speakers, rated for 160 watts-cost $39. So with tax and the metra Volvo kit, about $165-$170. The sound quality absolutely knocked my socks off.
The headliner is made of pegboard. It wasn't flexible enough to make the bends, so the two ends of the headliner above the doors are plastic lenses for fluorescent lights. Came out better than I expected. I probably would of done it in black if it weren't for the lens covers. Cost about $25 for materials. All in all I'm pretty satisfied with it. Its nice to have a radio and speakers too.
I also found this one that will help with wiring http://www.fordification.com/forum/view ... =8&t=64494
Stereo Options....Collection of Pictures
- KRob
71 F250 4x4, 4BT Cummins Mostly Done...Project Thread http://www.fordification.com/forum/view ... 22&t=65450
(4BT, big block ZF5, 78 NP205, 78 Dana 44 Front axle, 4.10, 265/75/16, power steering, power brakes)
01 Dodge 2500 4x4 Cummins...turned up a little.
- KRob
Re: Stereo Options....Collection of Pictures
Almost lost all of my above thread...so i decided to post and go back in and work some more on it......So still in the works, bare with me.
Here's the info on the Volvo dash install kit. http://www.fordification.com/forum/view ... 64&t=42987 (thanks, flyboy!)
- flyboy2610
You're welcome!sargentrs wrote:Here's the info on the Volvo dash install kit. http://www.fordification.com/forum/view ... 64&t=42987 (thanks, flyboy!)
For speakers, I used the Highliner from LMC. I have been very pleased with it, and I think the speakers that came with it are just fine for my tastes.
http://www.fordification.com/forum/view ... =a#p623507
Red Green
you'd better be right.
Red Green
- KRob
Thanks Gents.
Flyboy thanks for the info....I think your due a post on Frodo.
I am not too keen on the highliner, originally i liked it but i don't know now. I am going to pull my liner first and see what is a left and see if it is something i can make a good looking liner for.
- flyboy2610
Been doing 60+ hours a week at work. Just haven't had time to really do anything to him. I wanted to get the rear brakes redone this year. Didn't happen.KRob wrote:
Red Green
Red Green
Here is how I did mine. It is not my idea but it worked well. I sprayed the box with bed liner and coated where it is at the tank with foam camper topper tape. I attached it to the factory tank brackets with L brackets off the box.
1994 F150
1968 Bronco
1968 F350
1958 F100 Great Grandfathers Last Truck
1954 F100 Dad's First Truck
1968 Bronco
1968 F350
- Senorpablo
Here is the Retrosound Model Two:
