Will a dent front axle bolt into a bump 1/2 ton's radius arms?
Questions about 4WDs and related topics
Moderators: FORDification, Doug Comer
My427stang
Post by My427stang »
My old front axle has seen a lot of battles and with the new 445 I could use a bit more braking than the stock front drums
I am considering building a full dent front end and swapping, do the front control arms bolt up and are they the same width overall?
No worries on steering, because I am already running a dent steering box and tie rod assembly, just wondering about the axle housing itself. Thanks
71 F-100 SB 4x4, 461 FE, Edelbrock Pro-flo 4, 4 speed, 4 inch softride lift, all poly bushings, integral PS, most mods installed since the 80's
70 Mustang Sportsroof 489 FE, EFI, TKO-600 5 speed, 4.11s
Engine building by-appointment only--30+ years, specializing in strong street pump gas FEs
HIO Silver
Re: Will a dent front axle bolt into a bump 1/2 ton's radius arms?
Post by HIO Silver »
It'll bolt on.. except for maybe the spring cups. But that depends on what year your source the Dana 44.
It'll bolt in, but you also need the dent diagonal locating bar.
While you have it apart put in polyurethane bushings.
HIO Silver
cep62 wrote:It'll bolt in, but you also need the dent diagonal locating bar.
Colloquially, a "track bar". Technically speaking, it's called a panhard bar.
2x.. poly bushings.
My427stang
Thanks guys!
I agree on the poly bushings, I have run them since the mid 80s, they really work well.
Going to go hunting in the junkyard now, will rebuild a later front end and do the swap over the winter
shybutpsycho
Post by shybutpsycho »
Will the dent track bar bolt to the 67-72 frame? Come spring I'm putting 1978 Bronco axles under my 69 F100. I know welding is required on the rear end (spring perches/shock mounts), but was hoping the front axle is truly "bolt on".
shybutpsycho wrote:Will the dent track bar bolt to the 67-72 frame?
Yes
shybutpsycho
Thanks, time to order a dent adjustable track bar and plan this axle swap.
stldesign
Post by stldesign »
We are putting a 1978 dana 44 into a 69 f100 the 78 track bar doesn't fit. the angle of the ends aren't right. We have ordered a super lift adjustable track bar that will allow for some misalignment.
