The "Krusty Kab"
- popeyes71
Re: The "Krusty Kab"
Looks like the "patina" finish turned out good. Like you mentioned; it is weird painting with a brush and a roller on a car.
Craigerf100 wrote:Looks great man, some nice work you've done, and good progress![]()
What block is that, 351w? What heads and what cam?
The block is a roller block out of a 95 F150. I grabbed one at the local pull a part for not much at all. Even using the accessory brackets. They are being powder coated satin black right now. I need to take the alternator apart and do the same with the case. The heads are AFR 185 58cc heads. With the pistons that I put in I should be around 9.6 to 1 compression. Stock pistons are way below that on compression. The cam is a Comp Cam XE274HR I think. I can't wait to hear this thing run!
Barry
popeyes71 wrote:Looks like the "patina" finish turned out good. Like you mentioned; it is weird painting with a brush and a roller on a car.
No doubt but it works out well when you sand back down. The texture that the brush and roller creates makes the sanding process look much better. I just finished with the tailgate and half of the other bedside. I am hoping to finish sanding tomorrow evening and then Thursday start painting the cab and doors.
Barry
- Craigerf100
Cool cool, so it is a 351w? What HP and torque do u think it will run?IN2FORD wrote:Craigerf100 wrote:Looks great man, some nice work you've done, and good progress![]()
Barry
1968 F-100 Short Bed
1967 Fairlane 500 Convertable
1967 Fairlane GT/A 289ci SOLD
My Build:
http://www.fordification.com/forum/view ... &sk=t&sd=a
My Build:
Craigerf100 wrote:Cool cool, so it is a 351w? What HP and torque do u think it will run?IN2FORD wrote:Craigerf100 wrote:Looks great man, some nice work you've done, and good progress![]()
Barry
Yep it is a 351W. My build is similar to a build done in Hot Rod magazine last year I think. There engine made 500hp 500tq I think. Based on what I have read in other places such as Corral.net and similar builds as mine, I am guessing I should be around 400 to 450hp. I think 500 with basically stock displacement is reaching. If I had spent the bucks and stroked it, that should be easy but this was suppose to be a budget build. Turns out I blew past that along time ago...budgets...on a car project!?!?!?
Barry
- Craigerf100
Lol I hear that, mines a budget build but it's quickly racking up. Loving every minute of it though. That engines gonna be a beast! Great work and good luck
My Build:
My Build:
great build, can't wait to see it finished!
zmonster72 wrote:great build, can't wait to see it finished!
Me too. For that reason I have been skipping alot of car events are normally go to. I need this done so I can attend in my own!!
Barry
Bed is done with the exception of clearing it. I probably will do that with the body together.
![Image](http://i.imgur.com/lySAe8V.jpg)
![Image](http://i.imgur.com/1N0Tnui.jpg)
Pictures are kind of washed out.
Barry
Barry
- jimmy828
Can't wait to see it with the clear. That paint job is going to be different but will look good. ![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
- Jacksdad
Gloss, satin or matt? It would be a shame to make it too shiny when you clear coat it. That came out beautifully BTW ![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
- popeyes71
Looks like the patina finish turned out good; right on!
Like was mentioned, what sheen are you going to use for the clear?
Jacksdad wrote:Gloss, satin or matt? It would be a shame to make it too shiny when you clear coat it. That came out beautifully BTW
I totally agree. Nothing glossy. Most likely a satin or Matte finish but really I am not sure I need to use anything. The paint label does not recommend clearing it. I need to do some more reading.
Barry
If you don't clear it, it will oxidize and look more faded / aged.
Well I have a little update. Ordered some more parts for the front of the motor and waiting on them to come in. Stuff like tensioner, idler pulley, alternator, and AC compressor. I did some more painting on the motor and painted a portion of the heads black. Also installed the intake for the last time.
![Image](http://i.imgur.com/CTKkIjM.jpg)
![Image](http://i.imgur.com/Z0E0n7M.jpg)
Then I got the black , the red oxide primer, and the red sprayed on the cab.
![Image](http://i.imgur.com/j9kRXvy.jpg)
![Image](http://i.imgur.com/Cwb5BoB.jpg)
![Image](http://i.imgur.com/LS73Tez.jpg)
![Image](http://i.imgur.com/AOZkAqo.jpg)
I had hoped to sand the cab this weekend but they are calling for 70% rain this weekend sooo I will probably work on the motor some more and clean up the garage some. Might start working on my doors some. I need to weld up some mirror holes.
Barry
Barry
