Saving the Old Seat
Saving the Old Seat
Is there anything I can spray on or coat my seat in? The seat is in nearly perfect condition, no rot. I fear though that it will begin to disintegrate very rapidly if I start using it often. This is the closest picture I could find to what I have. My color scheme is tan and creame, but this design with the ford stamp on the backrest and leather is all the same. https://i.pinimg.com/736x/36/cd/90/36cd ... d-girl.jpg Thanks!
- 1972hiboy
Re: Saving the Old Seat
I would have a upholstery shop make a clear plastic seat cover for it. dont know much else you can do besides that.
Rich
Dont eat yellow snow.....
Good baby oil. Make a small towel sopping wet and drag it across the surface in small circles. You'll be amazed at how much dirt comes off a clean seat while doing this. Let it soak in overnight and then wipe it off. Might take a couple applications but it'll help keep the material soft.
Took his advice to use baby oil on my dash pad which was perfect but dull and it brought it right back to almost new and its already helped soften it up...........
1997 Honda CBR 900RR
I have the same concerns. I used Gojo hand cleaner to clean mine. No matter what i think the threads will start to disintegrate with daily use. look underneath, the burlap or whatever is there may be on its way out and the springs will eat into the foam. I plan to stuff some material in there.
1968 Highboy
1976 Highboy
1969 F250 Camper Special
1941 Dodge Power Wagon
1930 Model A Coupe (Hotrod)
VW Sandrails
Honda ATC's
1976 Highboy
VW Sandrails
Honda ATC's
https://ibb.co/dvvVfR
https://ibb.co/fD2Xum
https://ibb.co/dMECum
https://ibb.co/hVhbLR
https://ibb.co/khPZ76
https://ibb.co/dwr30R
https://ibb.co/k9iGLR
https://ibb.co/bQZO0R
Not smart enough to post individual pictures, dwr30R is my seat. I'm going to try the baby oil, that seems like it would work at least for a while! Thanks!
What GoJo does to your hands, it'll do to your seat.
You really want to add oil to the polyesters, not take it away.
