Project 'Smokey' - '72 Ranger XLT
- hdman90
Re: Project 'Smokey' - '72 Ranger XLT
Still, moving along at a steady pace!
Are you in the market for stainless West Coast Jr. hardware? There is a guy that sells them by the set, specifically for those mirrors, and his price is around $50 USD, which is an unbeatable price. Even comes with the studded cap bolts that are impossible to find!
If you're interested I could find some contact info for you.
- cdnwillyg
Looking great Steve, I was hoping you were going to mount the lower trim with the wheel well trim to see how that looked. Not sure how I missed this last update of yours????
Could you do me a favor and measure the holes along the bottom of the box for me as I need to drill those on my box?
Enjoying your build!!!
1968 Mercury M250 Camper Special
FE-390,570CFM 4bbl, C6 Automatic, PS, PB front disk.
Stony Plain, Alberta, Canada
:drive:Willy
:drive:Willy
- Bullitt74
Thanks for the offerhdman90 wrote:Still, moving along at a steady pace!
If I can get my work work done, I might be able to get to Fastenal this afternoon...
Steve F.
Red Deer, Alberta, Canada
- Bullitt74
Hey Willy! The trim on your truck is probably the wider 2.75" trim used on the Ford/Merc Rangers from 67-69, and Sport Customs 70-72. The 70-72 Rangers and Ranger XLT used a narrower trim that was single stripe, and 1.75" wide, and the bigger difference is the narrower trim package does not have trim behind the rear wheel. I suspect the holes are placed a bit differently due to the difference in trim width. Regardless, I'd be happy to provide the measurements if you wish.cdnwillyg wrote:Looking great Steve, I was hoping you were going to mount the lower trim with the wheel well trim to see how that looked. Not sure how I missed this last update of yours????
Enjoying your build!!!![]()
Check out: http://fordification.com/tech/trim.htm
Nope - you didn't miss the lower trim install, as I need to polish and remove a few dings from that lower trim (still in good shape, and this stuff isn't available repop and $$$$ as NOS). Polishing means removing the anodizing, so I've scheduled (...yes, I have a schedule of tasks posted in the garage for this build) this for when the weather warms up and I can spray Easy-Off sodium hydroxide and allow for chemical reactions when I have the garage door open.
Steve F.
- Bullitt74
Thanks for the kind words and motivation CrazyHorsecrazyhorse wrote:Mr Bullitt , I am enjoying "Project Smokey" thread.
You have a good looking truck that is coming together rather fast.
I have a red 72 Ranger XLT short bed and I like all the things you have done to your truck.
Please keep the good pictures , information & updates coming.
Thanks again and good luck.
Steve F.
- cdnwillyg
I think you are right on the sizing but the placement of the holes should be close is my guess, better than what I would guess for sure!
LMC shows all the same for 67-72 on the lower trim pieces.
So if not too much trouble would appreciate it.
:drive:Willy
:drive:Willy
Steve that trim looks so good!! It's gonna be a show truck when your done
- Bullitt74
Tackling the doors this week, and starting with the vent windows:
No wonder I had so much trouble rolling down the driver’s side window...check out the piled up rubber from the division bar!
Mark the division bar for reinstallation...
Pull the division bar straight down to get it apart. Wear gloves!
I didn’t have a small enough punch to get this roll pin out, so made due with a drill bit.
5 rivets need to be drilled out to get the vent rubber off.
Disassembled, masked and ready for gloss black paint...
Final paint turned out well. I’ll leave to cure in the warm basement before installing seals.
Steve F.
- Bullitt74
Steve F.
- cdnwillyg
Looking like new,
sound deaden-er sure takes away the oil canning in the cab...good move Steve!
:drive:Willy
:drive:Willy
I am so envious... I love this truck!
- cstoyer
Bullit74
Would you care to list what you used to paint the vent window assemblies? I currently have mine apart and am ready to paint them as soon as the weather warms up a little here.
cstoyer
cstoyer
68 F250 4x4
- Bullitt74
Mine appeared to be gloss black originally. I wanted a tough enamel that has some UV protection, so I went with rattle can Dupli Color black gloss wheel paint. Not sure if it’s enamel, as rattle can companies rarely label that anymore. I ended up with a few dust specks, but no runs or sags that I can see.cstoyer wrote:Bullit74
cstoyer
Steve F.
- Bullitt74
DuckRyder wrote:I am so envious... I love this truck!
Steve F.
- cstoyer
Much appreciatedBullitt74 wrote:Mine appeared to be gloss black originally. I wanted a tough enamel that has some UV protection, so I went with rattle can Dupli Color black gloss wheel paint. Not sure if it’s enamel, as rattle can companies rarely label that anymore. I ended up with a few dust specks, but no runs or sags that I can see.cstoyer wrote:Bullit74
cstoyer
cstoyer
68 F250 4x4
