replaced heater core today and while the box is out, I removed what was left of the old firewall pad.
worked my way to the drivers side an I'm wanting to remove the slide vent to clean all the dirt and leaves from 25 plus years sitting in a barn. took the 6 screws out but still wont come out. before I break it, someone tell me what I'm missing. shouldn't be that hard...thanks...steve
oh yeah...67 non ac
drivers side vent
Re: drivers side vent
Probably just the seal has glued it to the cab. I had to use a putty knife to cut the old gasket to release the vent.
Chris
Chris
-1968 F100 SWB, 4.6 3V, 5R55S auto, Crown Vic front and rear.
-1968 Cougar XR-7, 351C, AOD, Explorer rear. In approx. 6,000 pieces at the moment.
worked like a charm! went ahead and did the same thing on pass. side. both were full of sand and leaves.
on the pass. side, I found a rubber plug that was out. dirt ran down thru that hole and some came out inside the fender area.
I think there should be a water drain hole. I'm wondering if the plug came from somewhere else or should go back in. didn't find one on drivers side.
thanks for your help.....
after looking inside with the vents off, theres no place for that round rubber plug that I can see except up high in the corner and that plug is still there
Do you have to remove the e-brake assembly on the drivers side? I can't figure out how to get to that out to clean it witout pulling the e-brake.
no, unbolt it from the dash and firewall, then move it out of the way. no need to disconnect the cable.vossy wrote:Do you have to remove the e-brake assembly on the drivers side? I can't figure out how to get to that out to clean it witout pulling the e-brake.
1968 Highboy
1976 Highboy
1969 F250 Camper Special
1941 Dodge Power Wagon
1930 Model A Coupe (Hotrod)
VW Sandrails
Honda ATC's
1976 Highboy
VW Sandrails
Honda ATC's
yep
only 3 nuts to remove...easy job
