No dash lights......
Ohiotinkerer
Post by Ohiotinkerer »
Drove my bump to work last night and discovered at 1am i didn't have any dash lights.......all other lights work including the tach which is wired into the dash lights....dimmer for them works......tach light dimmer when I turned the knob back and forth. Only thing I can think of is i switched out the base model metal dash bezel for the higher end plastic one and it the lights used the metal one as a ground so now i need to run a ground wire.....am I on the right track of thinking............ :?
I didn't notice it before because this was the first time I've driven it after dark this year and they worked before this...... :help:
1997 Honda CBR 900RR
Thipdar
Re: No dash lights......
Post by Thipdar »
Ohiotinkerer wrote:Drove my bump to work last night and discovered at 1am i didn't have any dash lights.......all other lights work including the tach which is wired into the dash lights....dimmer for them works......tach light dimmer when I turned the knob back and forth. Only thing I can think of is i switched out the base model metal dash bezel for the higher end plastic one and it the lights used the metal one as a ground so now i need to run a ground wire.....am I on the right track of thinking............ :?
I'm assuming that you're referring to the truck in your sig... 1968?
As best as I can tell from the illustration, I think you're right. It looks like the lamps get power, but have no specific grounding wires.
Upgrading your upgrade might mean you have to swap out all of the single-wire lamp sockets and replace them with dual wire lamp sockets.
Good luck with it.
Ohiotinkerer wrote: so now i need to run a ground wire.....am I on the right track of thinking............
Yes I believe if you find which wire is the ground and ground it you should be all set.
Ohiotinkerer
Thanks guys......that was the only reason I could think of why they weren't working but with my luck if I didn't ask i would have melted half my wiring doing something I shouldn't have..... :eek:
Thipdar
Post by Thipdar »
Ohiotinkerer wrote:Thanks guys......that was the only reason I could think of why they weren't working but with my luck if I didn't ask i would have melted half my wiring doing something I shouldn't have..... :eek:
Not sure I really want to ask this, but...
...is it worth while to go back to your previous instrument cluster parts?
Ohiotinkerer
If I can't figure it out i will........but I really like the look of the one that I put in....... :D
