Steering column rubber boot
Suspension, steering, brakes, wheels & tires
Razorback
Post by Razorback »
I have searched forums and websites until I’m cross eyed. Can anyone give me a part number or source on the rubber piece around the steering column. This is from a ‘70 F100.
Re: Steering column rubber boot
Here's what I bought.
https://www.dennis-carpenter.com/trucks ... lumn-Seals
3rd one down C9TZ-3513-A
Razorback
Post by Razorback »
I have that part as well. That one stick through the firewall from inside to out I believe. This one I’m looking for was on the inside of the cab up against the firewall insulation.
390FE1972
Post by 390FE1972 »
I have never seen that part you are talking about on a factory set up? I have seen a number of these trucks in junk yards and have never come across that before. The only ones I have seen are the ones that Randy had the image of. Here are a few threads that show the rubber seal that Randy is talking about:
https://www.fordification.com/forum/vie ... =5&t=26830
http://www.fordification.com/tech/image ... column.jpg
http://www.fordification.com/forum/view ... =5&t=76673
http://www.fordification.com/tech/images/colshort02.jpg
Let us know if you find something out about it. Maybe someone added it over the years.
Regards :thup:
:yt: I don't recall anything other than the one boot and the metal plate.
Btw, the first one I mentioned is for a power steering column. Carpenter also has the one for manual steering which is what yours looks like. C7TZ-3513-B
sparky72
Post by sparky72 »
While we're at it, does anyone know a good source for paint that would match that green color on the steering column? Mine is the same color and eventually it needs to be repainted. I was thinking maybe one of those Duplicolor cans that you can get at auto parts stores that's for that dark green metallic that ford used in the late 90s, which would look good but wouldn't be perfect, obviously.
Taylor
1972 F250 Ranger XLT 2wd / 8100 GVW / 390 / T18 / 3.73 D60
70_F100
Post by 70_F100 »
After searching for several hours and pulling out most of my hair, it appears that the P/N for this grommet (or whatever you want to call it) is C4AZ-3512-A. It's not in any of the illustrations but I found it in a Ford automotive catalog. It was only used on trucks for a couple of years and I'm looking for the same part for my '70 Ranger XLT. Hope this helps!!
Wise men talk because they have something to say; fools talk because they have to say something.--Plato
Why is it that there's seldom time to fix it right the first time, but there's always time to fix it right the second time???
That's not an oil leak :nono: That's SWEAT from all that HORSEPOWER!! :thup:
1browski
Post by 1browski »
A little late but I just removed my steering column out of my 72 highboy and it has the same rubber boot.
