FORUMS WILL BE DOWN ON 8-28-07
- FORDification
- Site & Forum Admin
This evening we had some odd behavior on the forums, with some posts going missing, folks having problems either logging on or staying logged in, and the problem appears to be with our current server hosts. They've once again started bitchin' about how the site is "utilizing excessive resources" and have moved our site off it's regular production server and onto another server which has been known to cause problems in the past.
Therefore, it's time we finally make the big move from our current hosts to a new online home. I've already got it all set up...with one thing remaining to be done: I need to get a full working forum database backup done. However, the only way I can do this is to temporarily take the forums offline while the backup is being made.
The backup will take about an hour or so, so I'm tentatively planning on doing this backup tomorrow evening after work. Probably around 7PM CST or so, I'll temporarily take the forums offline for an hour or two while I attempt to get the backups made and downloaded. Once the backups are completed, I'll bring the forums back up online. I'll take this database backup and attempt to install it at our new hosts. If the backup is successfully installed at our new home, then I'll begin to make the move. However, the move will probably take a couple days, and after all other site files are moved over, I'll again have to take the forums offline, make another database backup and install that at our new home, and then transfer the 'fordification.com' domain name. Domain name propagation to all the internet's name servers normally takes 24-48 hours, so you will not be able to access the forums for a day or two.
I'll keep you all informed as to the status of the move. In the meantime, if you notice the forums are offline, be sure to check the site's front page (www.fordification.com) for an announcement of what's going on.
____| \__
-O-----O- Keith
My '67 restoration video
-O-----O- Keith
- 72stepside
re: FORUMS WILL BE DOWN ON 8-28-07
Whatever it takes to keep it going is fine with me!!!!!
Chris
72 F100 Stepside w/ 78 300 CID
Hedman Headers
Disc Brakes
Power Steering with 3 STILL on the tree
Comfy Crown Vic Seats
71 F250 PS, PB, AC, Auto, 390
Loooong way to go on this one!
Hedman Headers
Disc Brakes
- ezernut9mm
GAAAAAAAAAAAAAAAAAAAA!!!!!!!!!!!!!!!!!!!!!!!!
wanting to buy a mercury tailgate!
"the man who is swimming against the stream knows the strength of it".- woodrow wilson
Do what needs to be done. I guess while the site is down I may have to go outside and work on something. This domain change is going to cuase me to get something accomplished, I am writing my congressman LMAO.
Seriously though whatever it takes to keep the site running correctly is fine by me.
[quote="MOST OF ALL, pray about it. If God doesn't want you to go, he will make it clear.[/quote]
1967 F-100 Longbed (project truck) For sale $1200 http://www.fordification.com/galleries/ ... ?album=710
http://www.fordification.com/galleries/ ... ?album=726
1990 Blazer (offroad toy) 7 in. lift, 37 in goodyear MTR's
2000 Ford Focus (DD/commuter car) ABOUT TO BECOME TARGET PRACTICE!
2005 GMC 2500HD Ext. Cab Longbed (Towrig for the blazer)
2006 Kaufman 20ft steel deck car hauler (The only way the Blazer sees the road)
- kentdaryl
Maybe that's why I have a notification of a PM but can't find it.
- MadMaxetc
Good thing I am on vacation! I guess I will just have to sit out side and look at the mountains...dang
(my wife is happy to hear that I will not need to "check the board" for a while.
Dan
Project: '63 F-100 LWB / 460 / C6 / 2x4 / Work In Progress!
Daily Driver: '67 F-250 Converted to F-100 LWB / 300 / T-5 / 9" 3.70:1 / 235/75R15 Tires
1/4 mile in 17.64s @ 75mph (it's 4200lbs!!!)
"Work Harder! Millions On Welfare Depend On YOU!!"
FORD Girl
Photobucket Pictures
FORD Girl
- Thunderfoot
Hope it all goes smoothly for you Keith, Thanks for having such a great site
Shayne
I'm not "Brand Loyal" Ford-Chevy-Dodge-Toyota I have them all, one even cross mixed...
If it Looks good and Works good then it's ok by me. Everything has its issues from time to time...
69 SWB (project) & 69 Highboy (driver/project)
http://s197.photobucket.com/albums/aa29 ... d%20truck/
http://www.fordification.com/galleries/ ... ?cat=10399
- two-bit
Remember everyone, there is no need to panic!!!!
This is only routine maintenance, kinda like changing the oil in the bump.
You tell yourself everything will be OK, but your heart still doesn't start beating again until the oil pressure gauge needle moves after the first restart.
In the words of Winston Churchill...
"We have nothing to fear, but fear itself."
Be strong FORDification brothers and sisters.
I am sure Kieth knows what he's doing.
and remember, its only 24-48 hours.
Damn that seems like a long time!!!
Two-bit
Two-bit
Living life full throttle on the North Coast of America!!!
72' F-350, DRW, 360, NP435, Dana 70, 159" WB, P.S., P.B., 12' flatbed, 10,000 GVW.
- ToughOldFord
See you all at the back up Fordification Forums while we're down:
http://com3.runboard.com/bthefordificat ... m6772fords
I did not know there was a back-up forum LOL. Good to know though
- theskytoucher
Grrrrrrrr!!!! It wont let me login!!!!!!
Edit: it worked finally!!!!!
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
1976 Ford F-150 4x4
- FORDification
OK, I've done a backup of the forum database, and am currently attempting an upload of it to our new home server.
____| \__
-O-----O- Keith
-O-----O- Keith
- theskytoucher
Thank you keith for all your hard work to keep this site great running smoothly!!!!!!!!!
-Troy-
1976 Ford F-150 4x4
1976 Ford F-150 4x4
Re: re: FORUMS WILL BE DOWN ON 8-28-07
i changed my email address since i was last there and i couldn't remember my password. unless it wasn't me using my user name. that could be.ToughOldFord wrote:See you all at the back up Fordification Forums while we're down:
