BEZEL REMOVAL
- peanutman
BEZEL REMOVAL
Any tricks to removing the bezels behind control knobs on our bumps. Seen tool set made for this in npd. Hate to spend that kinda money for use once of twice. Used watch bezel remover on my ignition switch but it won't work on others.
http://s533.photobucket.com/albums/ee33 ... e_Johnson/
1970 302,ps, ac, 3 speed o.d.
- Supermike
You can try needle nose pliers, but if you aren't careful it's really easy to slip and tear up the chrome finish on the bezel.
You might check out this link:
http://www.fordification.com/forum/view ... hp?t=28280
Former owner of a '67 F100 Camper Special
Current owner of a 2022 Ford Bronco Wildtrak
- jzjames
re: BEZEL REMOVAL
just tap the notch with a screw driver in the circular direction that it is unscrewing.
re: BEZEL REMOVAL
