Question about Y-blocks
91Bear
Post by 91Bear »
Not bumpside related, but a buddy of mine has a '57 Ford with a 312 that has given up the ghost. Can he swap in a 292 that will bolt up to his automatic trans? I'm thinking the Y-blocks are interchangable but I'm not sure.
Will a non-Y block like a 302 bolt up to the automatic transmission, or would you have to swap an engine/transmission combo?
Wes
Re: Question about Y-blocks
Post by Wes »
a 292 y block will bolt right A newer V8 like a 302 will need the motor and trans combo
Wes
http://www.fordification.com/galleries/ ... ?cat=10402
67 F250 High boy
69 Bronco
If you can't see fit to stand behind Our Troops...Please stand in front of them :)
cbfomoco
Post by cbfomoco »
yes a 292 should bokt right in where the 312 was. Also a 272, 239 etc will as well. There might be some adaptors out there to put a 302 to a y block tranie you would just have to search around some as i think there are some to go the other way as well.
1994 F150
1968 Bronco
1968 F350
1958 F100 Great Grandfathers Last Truck
1954 F100 Dad's First Truck
AlleyCat
Post by AlleyCat »
You might want to give this site a try. :)
http://www.y-blocksforever.com/
Clay
ezernut9mm
Post by ezernut9mm »
i can't answer your questions, but there is nothing like the sound of a well built y gettin' with it.
http://www.youtube.com/watch?v=28gtzOJdHqg
wanting to buy a mercury tailgate!
"the man who is swimming against the stream knows the strength of it".- woodrow wilson
