Fitting
OldRedFord
Fitting
Post by OldRedFord »
I need a fitting like the one in the link, but the threaded end needs to be male inverted flare.
Is there such a thing?
http://fittingsandadapters.com/pusbarmalpip.html
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
Re: Fitting
Depends on the application. Inverted flare usually gets a good bit of pressure. Those push on hose bibs don't even get s clamp installed when you use the correct hose...
What's the application?
dssco
Re: Fitting
Post by dssco »
They're made but not common, 5/16 and 3/8 are the most popular. The fittings on inverted thread are straight SAE instead of tapered pipe like your example. What size do you need and whats it for?
OldRedFord
Re: Fitting
Needs to be 5/8-18 thread and a barb for 3/8 hose. It is for my Holley carb. After the whole deal with the chrome fuel line and asking around about it online I will just go with rubber hose for now.
Tim
Re: Fitting
Like this?
OldRedFord
Re: Fitting
Yup, just what I am looking for.
Tim
Re: Fitting
I've got them for 3/8" and 5/16" hoses. They are available at your local parts house (O'Reilly's, Napa, CarQuest, etc.)
Let me know if you can't find one, I'll send you this one.
OldRedFord
Re: Fitting
What is their proper name?
Tim
Re: Fitting
Re: Fitting
I think the "MRG-1543" Summit link might be the way to go for you.
OldRedFord
Re: Fitting
BobbyFord wrote:I think the "MRG-1543" Summit link might be the way to go for you.
So that would thread right into the bowl instead of using the fitting that is there now to reduce down? Like in your picture above.
Tim
Re: Fitting
Yes, if you click on "application" on the Summit link it says it fits Holley and Rochester carbs. Holley fuel bowl is 7/8-20 thread.
OldRedFord
Re: Fitting
Cool. Thanks for the help.
Tim
Re: Fitting
OldRedFord wrote:Cool. Thanks for the help.
No problem. Git that dang thing runnin' so we can all hear it!!
OldRedFord
Re: Fitting
:lol: Some of you are living vicariously through my build. :P
Tim
