Looking for Pictures of Custom Gauge Clusters
KRob
Post by KRob »
Hey everyone, I am thinking about building my own gauge cluster......these are some of the pictures I have found so far. I was hoping those of you that have done it before could add your thoughts and pictures! I am really not look for the F600 type, they don't appeal to me for some reason.
Wood Gauge Cluster http://www.fordification.com/forum/view ... er#p401588
Started from a F600
http://www.fordification.com/forum/view ... er#p620290
Image[/quote]
What i am thinking about doing is using a metal dash and building the center....fill in the open space of a metal dash like this one.
_______________AS I FIND MORE PICTURES I AM GOING TO ADD THEM BELOW______________________
http://www.fordification.com/forum/post ... 2&p=304564
From mcheath's project
http://www.fordification.com/forum/view ... &start=135
71 F250 4x4, 4BT Cummins Mostly Done...Project Thread http://www.fordification.com/forum/view ... 22&t=65450
(4BT, big block ZF5, 78 NP205, 78 Dana 44 Front axle, 4.10, 265/75/16, power steering, power brakes)
01 Dodge 2500 4x4 Cummins...turned up a little.
Broncobilly66
Re: Looking for Pictures of Custom Gauge Clusters
Post by Broncobilly66 »
Subscribed...
lets see some pics
'68 SWB custom cab Bump. Under construction.
'66 bronco
'68 bronco
KRob
Post by KRob »
Found another good one.
http://www.fordification.com/forum/view ... er#p322648
Image[/quote]
Thanks guys....I am really hoping we can get some pictures up for future guides.
tbone6
Post by tbone6 »
Okay, I'll bite...here's mine, still a work in progress.
t6
1972 F100
KRob
Post by KRob »
tbone6, that is a billeted one? correct? where did you get it?
Hey guys if you post pictures give a little info about them, bought or built....if built please provide more info
thanks
youngone
Post by youngone »
It looks like the ones from SNS
http://www.snsclassics.com/
tbone6
Post by tbone6 »
KRob wrote:tbone6, that is a billeted one? correct? where did you get it?
Yes, the insert is billet aluminum. I got it here, http://www.docskustom.com . Good folks to deal with. The cluster sheetmetal is from a 1968 (all metal). The gauges are VDO and the turn and high beam indicator lights are from a Harley Davidson.
:fr:
t6
1972 F100
tbone6
Post by tbone6 »
I do like this one, maybe done in a slightly darker stain. I might have gone this route if I had seen it before doing mine. The wood would match my plans for the A/C vents I am drawing up... :thup: :hmm:
t6
1972 F100
thejunkman
Post by thejunkman »
I sorta dig our stock gauges, however if I was going to build my own, I think I'd try to go even older school. Maybe graft in some 40s ford gauges. Something outside the box. May even from the sedans of the era.
-Dave
1967 f100 long bed 2wd, 390, np435
1999 Mercury Grand Marquis
KRob
Post by KRob »
Dont get me wrong i actually like the stock dash better.....but i am tired of dinking with 40 year old gauges. I am hoping to build this new dash with enough style of the old ones that it works.
67mann
Post by 67mann »
Here's mine so far..... Image
Clock face is scanned from images here, then blended together and re scanned for final image...gauges came from ( :hmm: ) ebay dealer
