I've got a 72 F100 and I think the steering shaft and wheel have been swapped.
Is there a way to determine which steering wheel I have to get the right steering horn cover?
Thanks!!
Steering wheel cover 72
- Mancar1
Re: Steering wheel cover 72
can u post a pic of your steering wheel.
It will either be a boomerang shaped pad cover, or a metal partial ring type. the older ones like my 68 have the metal type. If the shaft has several threads exposed after the wheel retaining nut is tightened then yours will be the padded type.
Keep on Trucking......John
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
About 1/3 of the way down the page tells about steering wheel configurations http://www.fordification.com/tech/67-72ID_01.htm
