intermittent wipers scott drake mustang
48prerunner
Post by 48prerunner »
Has anybody tried using the scott drake variable speed wiper switch for a mustang in our trucks?http://www.drakeautomotivegroup.com/Sto ... px?wid=141
mrollings53
Re: intermittent wipers scott drake mustang
Post by mrollings53 »
Don't know about that switch, but I know that the stock module and switch from a '78-'86 Ford truck/bronco plugs into the stock wiring. One side note, the '80-'86 switches need the windshield washer fluid portion rewired.
Here's a how-to:
http://www.fordification.com/tech/wiperdelay.htm
Common Sense is an Uncommon Virtue
48prerunner
Thanks I knew about the ones out of the 79- 88 ? i think has been a while since I drove the 87 ford I can't remember if the knob was like a pot and you could adjust speed or it just had a delay. Plus the old switches are going for $50 and up an flea bay . for $20 more new switch instead of an over 20 year old. Module on rock auto is over $200 and they go bad. I need to pull the switch and look at the plug see if it matches mustang. The have them for the 65-66 two speed and the 69-70 and the 71-73 mustangs
mrollings53
Seeing as how they kept the same pigtail for close to twenty years, I'd say it's a safe bet that it's plug and play. You may have an issue with the length of the shaft though, as that did change over the years.
two-bit
Post by two-bit »
Not to "rain on your parade"... However, that base of that switch looks pretty large.... will that fit into the same area as the stock switch ?
Living life full throttle on the North Coast of America!!!
72' F-350, DRW, 360, NP435, Dana 70, 159" WB, P.S., P.B., 12' flatbed, 10,000 GVW.
48prerunner
I don't know if it will fit in the stock spot in the dash . I'm more concerned if the plug looks the same. I plan on mounting it up in the stock f600 spot on the instrument cluster. I plan on using the washer function on the original switch in the dash for trip od reset on my electric speedo.
