crazyhorse » Fri May 06, 2016 12:18 am
Is there a simple way to trace the right front turn signal wire?
Much easier to go backwards by starting at the actual socket itself, (with the bulb removed).
1) Check for power to the turn signal light bulb socket, (usually a culprit).
2) Check for power to the harness that feeds the turn signal socket, (just behind the radiator support).
3) Check for power where the turn signal wiring goes through the firewall, (if memory serves me right the harness unplugs there).
4) Follow that same colored wire up into the steering column and check for power on the wire there.
Side note...this is hard to do with a simple test light-you can see an actual volt meter jump up and go back down much...easier.
Don't be afraid of a volt meter many here can easily walk you through how to read on if your not familiar with how to.
What year truck is it?
